Fueling Plate
Old Sep 28, 2003 | 09:13 PM
Campin Johny's Avatar
Fueling Plate
I am considering installing a TST #11 plate. Does this affect only full throttle operation? If I'm not at full throttle do the EGTs stay pretty much what they are now? The reason I ask is because I've had reasonable temps pulling my little trailer and never really needed full throttle even on hills. I don't want to lose that but sure could use more playing power going to work, around town etc. Thanks, John
Old Sep 28, 2003 | 09:21 PM
Mostwanted's Avatar
Re:Fueling Plate
The plate you are looking at would afect most of the entire RPM range. I have a California 12valve as well. Have you moved your stock plate forward at all? If not, you probley would be happy with moving your stock plate and save some money in the process. You will want to address the boost tho. I would recommend the turbo master (turbom_master.com) for this. I belive (someone correct me if I am wrong), a full forward stock plate will be the same as around a #4 plate.
Old Sep 28, 2003 | 09:55 PM
1dslram's Avatar
Re:Fueling Plate
A stock plate full forward is still less than a #8 and no where near a #4 plate. Why not get the #10 and then when you add the GSK you will have the right plate and not have to change plates to get the full use of the spring kit. Keep the #10 at the stock location or slightly to the rear. Be sure to adjust the governor arm, using the instruction from Piers web site. http://www.piersdiesel.com/LeverAdj.htm
Bruce
Old Sep 30, 2003 | 12:20 PM
y-knot's Avatar
Re:Fueling Plate
Give TST a call, thye are the experts, not only do they install all of there products, they are the creators. Do yourself a favor, and pick up that phone.
Old Sep 30, 2003 | 06:49 PM
BigBlue's Avatar
Re:Fueling Plate
What does a fueling plate do? Is the higher the number plate (10, 12, etc.) give more power? Or is it lower?
Old Sep 30, 2003 | 09:46 PM
1dslram's Avatar
Re:Fueling Plate
If you are looking for a very conserative answer call Mark at TST, for a more real world answer call AL or Piers at Piers Diesel Research. JMHO
Bruce
West Coast
Jul 1, 2007 02:32 PM
plow
Jul 20, 2005 08:40 PM
Rockcrawler
14
Jun 23, 2005 11:40 AM
banks twinram
Feb 5, 2005 10:38 AM
