Fueling, injector and chip question
Old Feb 17, 2008 | 03:52 PM
Purplezr2's Avatar
First off, but truck has an intank setup and a new VP thanks to the last owner. My question is does that provide enough fuel(I know, I need to get a FP guage, its the mounting of it I have not decided on or were to buy(suggestions welcome))
Second I see talk about injectors I have the following questions
1. Say I want to get stage 1 or 2 jammers is it as easy as just installing and bam i have the extra power or do I need to raise my fueling via a chip
Third is Chipping/box what every there called
I'm thinking something by quadzilla(the 120HP/325TQbox) as I don't have tons of money, but was thinKing maybe smarty, which is a better choice.
Old Feb 17, 2008 | 03:57 PM
wurkenman's Avatar
Depending on the chip/programmer you buy it may have a gage built in. The Jammer nozzles will require no extra fueling on their own.
Old Feb 17, 2008 | 04:10 PM
Purplezr2's Avatar
So if I go with like stage 2 or 3 jammers and This which appears to come with gauges Would that be bad, going to add exhaust too.
Old Feb 17, 2008 | 06:00 PM
nike's Avatar
It would run strong and smoke at will with those mods.
P.S. Im selling one of those as well... http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m32
Old Feb 17, 2008 | 07:58 PM
JStull's Avatar
purplezr2,
The sticks would need at least a boost fooler to appreciate them. You'll defuel just over 20 psi when stock. Any programmer or box that you add will take care of that. You can buy a stand alone boost fooler for about $50.
I'd go with something like you have in mind. The added timing is really nice and gives a lot of bottom end. That quad box will work great with a set of sticks like you are looking at.
I ran Jammer 4's for a while and really liked them.
Jason
Old Feb 17, 2008 | 08:08 PM
Purplezr2's Avatar
^^^ thanks
Next question I was looking around ebay(Guessing not the best place to buy performance injectors) but why is there a such a difference in price for what
appears to be the same thing see links
Cheapest
Middle
Top, sold by the same company and as the same thing as the middle ones
So which is the real deal, or were is the best place to buy them
Old Feb 17, 2008 | 08:12 PM
mishkaya's Avatar
Purplezr2
The last link you show is for the complete injectors, whereas the other two are just for the nozzles. That explains the difference in price. Unfortunately though I know nothing about where to get jammer injectors.
mishkaya
Old Feb 17, 2008 | 08:35 PM
nike's Avatar
I dont know enough to make a reccomendation. I will suggest buying full injectors over nozzles.
Im running 80 hp DDP. They run cool and dont smoke much but Im starting to want more.
Maybe here?-> http://www.f1diesel.com/injectors24.html
Old Feb 17, 2008 | 08:47 PM
scottsjeeprolet's Avatar
I think with the stock charger and fuel system Jammer 5's are too big for now. Stay with the 2's or 3's, I bought used DDII's on Ebay for $300 and couldn't be happier with the extra power. But i also have BHAF, Exhaust and gauges. See my sig. Your also gonna need a clutch upgrade & boost elbow.
Old Feb 17, 2008 | 09:11 PM
Purplezr2's Avatar
Ok so order of mods
gauges(if I get the XZt with recon I should be good)
XZT
Exhaust
Sticks and boost elbow(this is like a boost limiter/upper correct)
I have played with 1.8T VW motors for the last couple years but diesel is all new to me.
Old Feb 17, 2008 | 09:14 PM
mishkaya's Avatar
Purplezr2
make sure that whatever gauges you get, that you have a fuel pressure gauge as that is one of the most important ones on a VP44 truck. I am not sure the quad setup comes with one or not. Other than that, it sounds like a plan.
mishkaya
Old Feb 17, 2008 | 09:25 PM
nike's Avatar
The fuel pressure is an option with the Recon. One problem with the Recon guage. You can only view one parameter at a time. Ex. boost, fuel, pyro.
But you can download different programs with the XZT. Only thing else comparable is the Smarty.
kicker210
Jan 4, 2010 07:25 PM
Beast2B
21
Apr 30, 2009 09:43 AM
Mr. Jimmy
Oct 29, 2005 12:34 AM
cowdude
Feb 19, 2003 06:20 PM
