what is it comp.or drag comp.?
Old 02-16-2008, 09:09 AM
country ...boy's Avatar
I bought my comp. off e-bay last year to up grade my e-z and was under the impression it was just stock .The other day I was out running her hard to see if I had fixed my wire tap problem that was giving me codes I noticed I could run the rpm's up to 3200! I thought 2800 was the end? but have never really watched be fore now So guys what have I got ? Thanks
Old 02-16-2008, 09:19 AM
6speedcowboy's Avatar
I'm pretty sure that the 24 valve will go to 3200 rpm stock. mine will rev that high too
Old 02-16-2008, 09:36 AM
Do you or any body know how high she will rev with the drag option unlocked? Thanks
Old 02-16-2008, 10:03 AM
GFB
GFB's Avatar
It's just a matter of how hard the box fuels up high. The drag comp keeps fueling hard 3200-3400 I believe.
Old 02-16-2008, 01:00 PM
Ph4tty's Avatar
With an EZ or comp the truck will fuel hard to 2700 rpms, but with the drag comp it will fuel hard to 3200. If you don't feel the power dropping of at 2700 rpms then it must be the drag comp.
Old 02-16-2008, 04:30 PM
Ph4tty my truck has lots of power up to 3200 and feels like it could go more .It shocked me when I saw I was up that high and closing in on red line so I let off and have not tried it agine. Maybe I do have a drag comp.!
Old 02-16-2008, 06:23 PM
Tate's Avatar
Flip the box over, there should be a Hot Version sticker and a date on which it was done if it is a Drag Comp.
Old 02-17-2008, 08:26 AM
Tate There is two stickers 1 says its the 8.0 version with years it fits,2nd has a scanable bar code ,says warranty void if removed. I dont see nothing about hot on it ?
Old 02-17-2008, 03:00 PM
Tate's Avatar
My drag comp had two stickers, one which said Hot Version, and the years it fit. Pictures of it are on my other computer. Sounds like the reg comp to me.
Old 02-17-2008, 10:30 PM
MSquare's Avatar
Call Edge and have them run the serial number. No more guessing.....
joefarmer
20
12-11-2004 05:25 AM
White00
11-19-2004 09:18 PM
ratsun
09-26-2004 11:16 AM
MoreSmoke
01-07-2004 09:40 PM
hellotbone
18
05-16-2003 04:40 PM
Quick Reply: what is it comp.or drag comp.?
