Fuel Pressure Seems Low
From: Newman Lake, WA (But my home is deep in the heart of Texas!)
I know that the topic has been beat to death but after the install of a 0 - 30 psi Westach fuel pressure gauge I am showing 10 - 12 psi at idle, 8 - 10 with a light foot and 2 - 4 dropping the hammer.
The gauge setup is a tapped Banjo at the VP which runs via a hose to a sending unit at the firewall then to the gauge. I called dodge and they will do a flow test on the LP. I don't want the intake replacement if possible. Should I be concerened at this point....I have been babying the truck all morning worried. Like I said, driving "normal" I see about 8 - 10 psi.
I am at 62k and four years.
Thanks!
Thanks!
Thanks jimmyCTD, I appreciate the input. I am contemplating going to a dealer but I am afraid they will say "well, it pased the flow test...75.00 please".
I am looking into something cheaper than the FASS that will give me higher pressures....any suggestions?
Tom
I am looking into something cheaper than the FASS that will give me higher pressures....any suggestions?Tom
Dealer would force the in-tank pump on you anyway.
You could try the "campaign pump" from cummins,
under $70 and supposed to be better than the original.
Sorry, don't have a part number, but a search should find it.
phox
phox
phox
phox
Thanks again!
Tom
Tom
Tom
i have the vulcan kit still sitting on my shelft with a new LP ready to get installed. Just been lazy. Ive also never floored my truck but im sure i can draw it down below 5 at WOT if i wanted too.
ill post numbers once i get the kit installed. new LP and vulcan kit ran like 300 bucks. cheap insurance. i just need to install it.
I think my numbers are 13 @ idle, 9-10 @ 70-75mph with or without trailer and floorboard, well it takes a long time to pull it down, even with a load, I think the lowest I have seen to date is around 7ish. I'm going for the Vulcan big line kit in a couple weeks then see what it does to the fp.
Thanks guy's! Now, whats youre opinion on me going to DC (I am still under warranty) and explaining to them that if I get on the pedal as in highway acceleration it drops below whats good for the vp (2-4 psi) and ask for a new LP regardless of what type of flow test they do. I could even let them drive it to prove that the LP is going south. Do you think that would consider a replacement? Surely if a tech drove my truck in a normal fashion on and off the highway and saw that the pressure are too low they would know that the vp is at risk. They do know all this stuff we do.......don't they?
JThiessen
16
Aug 22, 2009 02:46 PM
bc3
Dec 1, 2007 10:19 PM
beaver76
Nov 11, 2007 11:24 AM
