fuel pressure line slowly leaking
just got a brand new mechanical fuel gauge with isolator: from the isolator to the gauge, tube is filled with 50/50 water anti freeze. I bled it properly, but I noticed the fluid level is slowly going down. I can not see any leak at all. My fear is the water is leaking past the diaphram in the isolator and into the fuel side. Any suggestions?
It's not, If anything, it would go teh other way. Fuel into the glycol side.
It's still in there, just below your sight line. It will not affect gauge performance.
Dave
Dave
I know this suggestion is not "legal", but ditch the isolator, run a good diesel rated rubber fuel line with a needle valve and good hose clamps right up to the gauge. I had so many leaks with that plastic line it was not even funny...
X2!! i ditched the compression fittings and plastic tubing and put on 3/8" fuel hose with hosebarb fittings and hose clamps. works like a champ!!
i am currently running the plastic line with compression fittings right into the cab from the vp44. i am also using a needle valve.
so far no problems yet, how long did it take before you guys started to see leaks?
It started leaking right away. I prefilled the isolator too. I just don't see where it is leaking. So I'm going to detach it from the I.P. side and observe if antifreeze is leaking from the diaphragm.
I sure would like to know the correct way to tighten them. Mine has leaked from day one. I have replaced the ferrules and the lines several times. Now I have grease gun hose on it and it still leaks down, but not as quick. Not sure where, But I think its under the hood at the isolator. Is it possible to use some other type of fluid in there that will not leak like anti freeze? What is the best sealant to use on the threads of the pipe fittings? Any thoughts or help would be appreciated.
Chipmunk Diesel
10-13-2004 06:28 PM
