fuel pressure gauge
Old Jun 20, 2005 | 05:54 PM
sum800mit's Avatar
fuel pressure gauge
where's the best place to install/connect for a fuel pressure gauge? Looking for location(s), photos would be nice. Have the gauge, isolator and lines. Just need to hook it all up. Thanks for the help.
Old Jun 20, 2005 | 06:06 PM
CTD2001's Avatar
I installed mine on the schradder valve on the Vp 44 pump, i believe there is a picture of it in my gallery. I had to get a couple of fittings from the local Napa to be able to fit the fitting that came with the gauge kit onto the schradder valve. I know that other guys hook theres up to the bottom of the fuel filter canister. Let me know if you have more questions
Old Jun 20, 2005 | 09:24 PM
Mopar1973man's Avatar
Here you go...
This is my setup with a banjo bolt and needle valve... No Isolator...
Here is the parts used on the above picture in a exploded view so you can see them...
I hope this helps...
Old Jun 20, 2005 | 11:05 PM
Walt L's Avatar
I did the fuel line upgrade to facilitate the FP gauge w/ isolator. Check my gallery for pics
Old Jun 21, 2005 | 05:07 AM
crobtex's Avatar
Mine is set up the same as this. Thanks to Shovelhead for the pic.
https://www.dieseltruckresource.com/...cat/500/page/2
dodgeguy71
17
Jan 19, 2012 12:52 AM
Igor
Sep 13, 2005 12:47 AM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
