fuel pressure gauge
Old Aug 31, 2004 | 01:23 PM
nubby3's Avatar
fuel pressure gauge
My fuel pressure gauge kit finally coming in today.Can I remove the schrader valve on the vp an install tapped banjo bolt or should I install tapped banjo bolt on bottom of filter.I am installing a mechanical Isspro in cab,no isolator.What kind of sealer should I use on threads.
2001 3500,auto,ez,K&N,4"magnaflow,turnbuckle on turbo
Old Aug 31, 2004 | 01:56 PM
Palmetto_kid's Avatar
Why dont we use isolators again? I forgot. My friend is installing a dipricol mech. gauge, and I wanted to tell him something about the isolator, but I cant remember the problem with them.
oh yeah, read your FP at the VP, not the FF....lol.
Old Aug 31, 2004 | 05:47 PM
Homestead's Avatar
Bottom of the filter is fine. It will also eliminate some of the hammering that results from tapping into the shrader port. It just saves a little buzzing at times when you go into the filter housing.
Old Sep 2, 2004 | 05:54 PM
Moose10's Avatar
From what I've read here, the isolators are prone to failing from the vibrations, and like many will say, if you use quality fittings and a needle valve to dampen pulsations to the gauge you should never have to worry about a leak with no isolator.
Also Rod from Wildcat told me not to go off the VP with a straight line to the gauge....can't remember why exactly....but I listened
Anyway, I got Permatex pipe thread sealer from Napa for all NPT connections.
Old Sep 3, 2004 | 12:51 PM
nubby3's Avatar
What are yall using on the bottom of filter.I have a tapped banjo bolt,needle valve,reducers,& a 6' hose.It sure looks like a lot of weight on filter housing.Do I have to remove the filter housing to install.
dodgeguy71
17
Jan 19, 2012 12:52 AM
Igor
Sep 13, 2005 12:47 AM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
