Fuel Pressure
Fuel Pressure
Hey guys i think this is in the right place haven't posted in a while. I would like to know what you all consider a safe fuel pressure in a 00 24v CTD with the stock LP setup. Also how do you guys like the galcier deisel walbro setup or would i be ok with just doing the vulcan kit and moving the lp to the frame rail. Thanks for all the help
The FSM says 10 psi at idle is the acceptable minimum.
As far as choosing the aftermarket solution, there are many options. Search for "fuel pressure" or "lift pump" and you will see hundreds of messages on the subject. In short, FASS or Walbro are the two preferred choices for performance and reliability, and in a pinch a relocate kit or supplementing the stock LP with a frame located pump seems to work for many people.
-P
-P
dodgeguy71
17
01-19-2012 12:52 AM
bigragu
01-24-2006 11:16 AM
mtl0727
11-05-2005 06:47 PM
darrenG
06-28-2005 07:43 AM
Flatty
01-05-2005 02:50 PM
