Fuel Pressure
Old Mar 2, 2007 | 07:32 PM
tweeder_51's Avatar
Fuel Pressure
My fuel press readings are jumping around I'll be drivin and it will run at about 7 then jump to 14 and back and forth, is this a sign my LP is goin out?
Old Mar 2, 2007 | 07:53 PM
cejrunner's Avatar
tweeder,
mine did the same thing about 2 years ago (6mo. old lp) i paid it no mind. Then without warning (we wont discuss what happened to the pressure guage) and yes with no pressure guage hooked up, it shut down in the middle of the interstate. No check engine light or anything. That cost me big time. So, with that being said, monitor your fp close and if it keeps happening and drops lower, replace the lp. Wouldnt be a bad idea to do it anyway. There are a few choices for you and different preferences. Check my sig to see the route i went. Best of luck
Old Mar 2, 2007 | 07:57 PM
tweeder_51's Avatar
Thanks, I've been quoted at $225 for LP and install, is that a fair price?
Old Mar 2, 2007 | 08:05 PM
cejrunner's Avatar
that seems fair. However, you could add just a little more to that and be done with the original lift pump and all its problems. FASS offers a pump only option which i went with and has a good warranty. there is also a walbro kit. you can search both and come to a conclusion.
Old Mar 2, 2007 | 08:12 PM
tweeder_51's Avatar
Thanks for the tips I'll do some research
Old Mar 2, 2007 | 08:27 PM
scottsjeeprolet's Avatar
That's not a good price!
You can get a Campaign pump from your local Cummins dealer for about $70 and put it in your self.
Old Mar 2, 2007 | 09:21 PM
Muddin_dude06's Avatar
I would do a system like the FASS, I put one on my buddies truck and it is pretty sweet.
Old Mar 2, 2007 | 09:48 PM
Geico266's Avatar
Definately. Go with the FASS system and you'll end your LP worries.
dodgeguy71
17
Jan 19, 2012 12:52 AM
bigragu
Jan 24, 2006 11:16 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
