Fuel Plate
Old Jan 14, 2005 | 12:42 PM
squirlchasr919's Avatar
Fuel Plate
Almost ready to install a set of twins, still need a few things. One being a different fuel plate. I was thinking a #0 but it will be a street driver and tow occasionally, maybe the #0 is too aggressive off the bottom for normal driving?
Then I thought #100, same streetability as the #10 but #0 top end.
I already have a #6 Kit I was sending back to TST to exchange for the #0. With the exchange it is only $50. I asked about the #100 and they had never heard of it. So who makes one where can I get it? or should I get a #0 insted?
Thanks
Old Jan 14, 2005 | 12:56 PM
signature600's Avatar
You have to make the #100. You can grind your stocker or grind a new one, it's up to you.
Chris
Old Jan 14, 2005 | 01:41 PM
BIG&BAD's Avatar
heres info on the 100plate
https://www.dieseltruckresource.com/...ight=100+plate
Old Jan 14, 2005 | 10:47 PM
got...DIESEL?'s Avatar
I don't have enough air or pump to put the 100 to the true test YET, but I will tell you I ran a #0, and changed it to a 100 and it really help not "puttin out the fire" off idle. alot smoother power as well. Just be sure to make AFC changes to get the rack on the plate and off the AFC lever.
Be sure and fill out your sig so members can help you out, based on your build outline in that sig.
West Coast
Jul 1, 2007 02:32 PM
plow
Jul 20, 2005 08:40 PM
Rockcrawler
14
Jun 23, 2005 11:40 AM
banks twinram
Feb 5, 2005 10:38 AM
