Fuel Plate
Fuel Plate
I installed a #10 plate in the stock position,afc houing ahead,star ahead. When I step on the loud petal I have to be easy, If it goes to far it takes off like a rocket. If I slide it to the rear would this cure the problem and have enough fuel to the eng?
You can put it anywhere you want. Plate position will only make a difference if your at fuel throttle the govenor arm only contacts the plate at this time.The starwheel adjusts the preboost fueling, the afc is more of a dramatic change in the midrange power. Everything forward isn't always the best idea.
West Coast
Jul 1, 2007 02:32 PM
Rockcrawler
14
Jun 23, 2005 11:40 AM
banks twinram
Feb 5, 2005 10:38 AM
