Front drive shaft
Old Oct 17, 2004 | 05:57 PM
MCMLV's Avatar
Question Front drive shaft
I am reposting this from another thread because I do need some advice soon please.
Life is life and nothing is perfect.
Not even my new aux tranny install. Discovered small problem. The foront drive shaft, being longer now (the transfer case moved back about 12 inches, to allow the tranny to be bolted between the stock tranny and it) on a full extension of the suspension (like when you hit a large depresion in the road) touches the cross member that holds the tranny (stock) in place. The cross members has to be nothched a bit to accomodate this. No big deal except I do not have the time to have it donne. My trip to Tacoma has moved up two days, MY SON IS COMING HOME FROM IRAQ two days earlier. This week I have a lot of loose ends to tie up before I leave next Tuesday, and this work will need at least two days in the shop. So I am thinking the following: Is there any reason why I should not just remove the front drive shaft for this trip, I really do not expect needing 4 wheel drive, and have it all done right when I get back?
I appreciate any input. Thanks.
Peter
Old Oct 17, 2004 | 06:09 PM
apache's Avatar
Im not sure if your uses the vacum disconnect like my 95. I dont see an issue doin it. If I remember with the vac disconnect set up the front dont spin in 2wd anyhow. yank er out. BTW, hope your son is home to stay and doin great!!
Old Oct 17, 2004 | 06:50 PM
joefarmer's Avatar
I've run without a front driveshaft at times. Other times I've run without the rear shaft. I wouldn't recommend it long-term, but running without the front driveshaft won't hurt the truck at all.
brandon.
phox_mulder's Avatar
Re: Front drive shaft
Peter
Yank away.
Even if it is an early 2002 with the CAD, it shouldn't matter.
I removed mine for a week chasing down a vibe, and had no problems.
phox
Old Oct 17, 2004 | 07:33 PM
MCMLV's Avatar
Thanks guys, just keep in mind, I am about to do about 6k miles without it.
Old Oct 18, 2004 | 07:42 PM
MCMLV's Avatar
Thumbs up
GOOD NEWS
I took the truck in this morning to have the front driveshaft removed. The service manager looked at the problem and said he'll have the whole thing done by late lunch time, so I do not have to go without 4X4 on the trip. AND HE DID HAVE IT FINISHED. He did not even charge me for this additional work.
Now I am ready for the trip, I am so excited, almost like a little kid (I think I'm geting old, do not tell anyone.) God willing everything else will go well.
PS Thanks for the prompt advice, it is much appreciated
Old Oct 18, 2004 | 10:20 PM
Sidewinder's Avatar
Now I'm curious! How did they fix it? Don't leave us hanging!!
Old Oct 19, 2004 | 08:36 AM
MCMLV's Avatar
Oh, sorry about that.
They supprted the tranny assemblies, took off the cross member and notched it , just a bit not much was needed, took off the drive shaft and checked it to make sure it was not damaged. Put it all back and lifted the truck by the frame letting the suspention fully exted to make sure there were no more clearance problems.
TON4FUN
Aug 2, 2004 07:58 PM
cwbronc
Dec 21, 2003 02:48 PM
shaft
Jun 30, 2003 02:37 PM
bkay
Dec 12, 2002 05:22 PM
