free GSK for the p pump bunch
Originally Posted by Lil Dog
Hearing about the 97 problems is what I was afraid of.. Not all governors on the 215's are the same.. Some have shims, some have a couple springs.. Hmmm, might have to cough up for spring kit..
Thats the problem I have been seeing. Every install has a different setup depending on the pump year.
I will have to re-read the thread here and see the exact thickness of washer. I was thinking of getting some machinery shaft shims as they are harder and may fit better?? I dunno.. Sorta afraid to try... I don't really want to test my Positive Air Shutoff...
I just installed a 3k kit on a 160 pump and it pulls hard almost all the way to 3000, i have to let off because i am not getting enough fuel up top i think , i get up to about 2700 and it spits and sputters white and blue smoke.So i am getting my timing at 17*.
would this free gsk work with this already installed or am i just to stay with the 3k GSK ?? I plan to get the #60 valve springs , so i want to rev to 4k . so once i get the valve springs should i install the stock govenor springs and do the free gsk mod?
Nothing wrong with your 3k GSK. My '95 with the 160 pump and 3k kit pulls hard all the way to 3250rpm.
Originally Posted by MikeR
Have you check your lift pump pressures and if your overflow valve is good. That's the indication of no fuel on the top-end.
gonna try to do this mod tomorrow if i get home from the hospital in time... sounds like it is a great find when it works and heres to seeing if it will work on mine without blower the ever faithful auto tranny... well here we go!!
Ok, I JUST finished up this mod about an hour ago...I have a 96 180 pump (Ca, EGR....but EGR eliminated). I can free rev the engine to about 3400, and it pulls to about 3000 then my boost rapidly drops from 38 psi to 20-23psi. I also am having the hanging RPM problem....right about 2K. If I turn on my exhausst brake for a moment and shut it off, idle goes to 650 and stays. This of course is after adjusting the slow idle stop. I am going to back off one click tomorrow so I will report.
On the rapid boost loss, could that be my wastegate opening too soon? I have the vacuum line to it plugges but I am thinking I need to clamp the wastegate closed. HELP!!
Originally Posted by Cummins Freak
this wont work on our 97's did i read that right. any why not ???
Originally Posted by nevrenufhp
From what I gather, it seems to only work on the 94 & 95's.
later i did it to my 94 manual ... same! excelent!
what washer did you guys use?
I drawed this today, in a hurry to help a guy with it:
http://www.cumminsforum.com/forum/at...4&d=1149799982
