Fpg
Fpg
Well the search function isn't workin so I'll ask here. I have the airdog installed now I need a Fuel Pressure Gauge. And they are friggin expensive. Does anyone have a fuel pressure gauge kit for the lines now. Something that would splice into the actual line would be great.
If your wanting a mechanical guage just cut the line get a 1/2" brass T 2- 1/2" brass hose barb fitings, and one bushing that is 1/2" male x 1/8 NPT and you should be able to hook right into it.
I asked the same question, but a little more general...
https://www.dieseltruckresource.com/...d.php?t=227101
Hope this helps
Hope this helps
There's a few ways to get a fuel pressure port. You can use a swilev 90* pushlock or a pushlock T as mentioned.
Here's a pic of the 90* I don't seem to have the straight fitting pics handy.
Dave
Dave
Hope this helps
Hope this helps
Theres a few ways to do an install on an 01 -
Fuel filter outlet using a tapped banjo bolt:
VP-44 test port:
Also, if you have a big line kit you can use a pushlok fitting like Dave is showing above.
Does this go straight into the VP??? I have an airdog on the truck, so that T would be great because that is what I have on there now!! Easy install!!!
davelinde
09-13-2006 10:21 PM
davelinde
16
05-14-2006 07:49 PM
davelinde
05-14-2006 12:20 PM
