fp gauge????
Old Feb 12, 2005 | 10:30 PM
Lrdchaos's Avatar
fp gauge????
I am going to put a set of gauges on my truck, has anyone run an electric fp gauge? I can run either and electric or a gauge that runs the isolator. WHich gauge would you recommend?
Old Feb 13, 2005 | 11:40 AM
Vulcan's Avatar
I installed a Cyberdyne digital fp gauge a couple of months ago, seems to work well and is very reasonably priced. $79 with sending unit from Jegs.
Old Feb 13, 2005 | 11:58 AM
Buckshotmckee's Avatar
I just got the new Autometer Z-series 0-30 fuel pressure gauge. So far so good. The kit came with everything but a Banjo bolt to plumb into the Vp-44.
Old Feb 13, 2005 | 01:33 PM
mkubacak's Avatar
ISSPro EV mechanical 30 psi with no isolator. Just a needle valve and no leaks.
Old Feb 13, 2005 | 02:36 PM
rockwithjason's Avatar
I run Stewart Warner electric fp with dual senders pre and post filter. I have had no trouble with mine other than a missing insulator on one of the contacts. I got them from XK unlimited in CA. If I remember right the gauge and both senders was about $100
Old Feb 13, 2005 | 04:14 PM
infidel's Avatar
An mecanical $8 back mounted, liquid filled stainless steel US Gauge, no lighting, a needle valve and boost tubing for a total price of $21.
Eight years and 200+k without a problem, looks good too.
Old Feb 14, 2005 | 01:20 PM
Moose10's Avatar
Same here !....I've got some pics of the hookup to the bottom of the filter housing & needle valve. It's a bit different now with the FASSII....no more banjo bolts, and all -6AN line now.
I've got the Geno's 4/1 (one is tapped 1/8"npt) high flow banjo kit for sale.
Old Feb 14, 2005 | 07:38 PM
AggiePhil's Avatar
What are the different schools of thought on where to tap into the fuel system to run the tubing to the gauge?
mtl0727
Oct 12, 2005 01:02 PM
Igor
Sep 13, 2005 12:47 AM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
