Fass Install
Fass Install
I am going to order a FASS system this week for my truck. The third lift pump is dying with only 70,000 on the clock. So I am droping some cash because I am fed up with lift pumps. I know that there are a bunch of you out there with the FASS and was looking for some tips on intallation or anything that you wished you would of done differently.
Thanks in advance
Thanks in advance
Other than taking your time and being patient, it is a fairly straightforward installation. Trust me, if I can do it be myself, anyone can!
One tip though, it is a lot easier if you loosen the straps on the fuel tank to lower it a couple of inches. This will make it easier to remove the quick-connect fitting on top of the fuel sender.
BCarmicle
13
Nov 7, 2005 04:20 PM
Buckshotmckee
May 23, 2005 12:08 AM
Flatty
Apr 25, 2005 12:49 PM
