FASS II Question
Old Apr 22, 2005 | 11:57 AM
Bocifus's Avatar
FASS II Question
I've been running the FASS II for a little over a month now. 24 psi at startup, confirmed with a mechanical gauge. Question is, how do I lower the psi? Details please.
Thanks,
Casey
Old Apr 22, 2005 | 03:33 PM
Stamey's Avatar
Put your foot to the floor, and if your injectors are big enough it will drop, a little.
I'm not sure how that pump is adjusted. Did you call DPP about it?
http://www.dieselpp.com/
Chris
Old Apr 22, 2005 | 03:43 PM
I SPEED's Avatar
Which pump do you have? I'm running the 95GPH and I've only seen 20psi once (when it was first installed). Usually idles around 17psi.
Old Apr 22, 2005 | 04:17 PM
Bocifus's Avatar
95 gph. Sits at 24 psi @ idle wot down to about 20 and cruise is 22 - 23 psi. I know it has to do with the spring, but am not sure if I need to compress it or stretch it. Sent off an email to DPP, thought maybe someone might know.
Casey
Old Apr 22, 2005 | 05:50 PM
gandrews's Avatar
When first purchased my Fass II (95gph) would idle at 11 to 12psi and at wot would pull to 8psi or a little less. I had hoped for a little more pressure (say 15 to 18 at idle).
DPP sent me a new spring - it now idles at 20+ and I can pull it down to 15 - which is close enough. Thanks DPP!
FWIW - In addition to the spring they sent a new o ring, gasket and instructions.
Good luck,
George
Old Apr 23, 2005 | 01:34 PM
JStull's Avatar
bocifus,
try relaxing the spring. My replacement spring from dpp was much stiffer than the stock spring. pressure went from 10psi at idle to 20 psi at idle.
Thanks,
Jason
BCarmicle
13
Nov 7, 2005 04:20 PM
Buckshotmckee
May 23, 2005 12:08 AM
2wheelsup
May 17, 2005 10:45 PM
Flatty
Apr 25, 2005 12:49 PM
ralphie
Apr 21, 2005 12:51 PM
