FASS 150GPH and stock tank pickup... go or no go?
Old Dec 24, 2006 | 02:44 AM
NotMatt's Avatar
Alright, I ordered my FASS and a Vulcan draw straw from Eric @ Vulcan, and I haven't received the draw straw yet but the FASS has arrived. The manual for the 150gph FASS says that a larger tank pickup is "recommended"... can I install the FASS tomorrow so I can stop being stingy with the throttle (also just installed a new Edge Juice w/Attitude), or am I going to burn up the pump on the FASS or something if I don't install the larger tank pickup at the same time?
Advice please... I have limited shop time/space available, so I'm trying to maximize what I can get done in the next couple days, and then I will drop the tank over the new years weekend and get the draw straw in...
Old Dec 24, 2006 | 02:50 AM
Tate's Avatar
Put in the FASS, and install the draw straw when you get the chance. I've got a year on my stock pick up and 150 fass, and its still running good.
Old Dec 24, 2006 | 09:43 AM
RowJ's Avatar
Is it a Model 150/150 gph... or the 95/150 gph?
Either way I believe as long as you do not have the in tank lift pump it will work fine with, or without, the Draw Straw! I know it will on the 150/150.
My understanding is that warning is only for the in tank pumps.
RJ
Old Dec 24, 2006 | 10:54 AM
NotMatt's Avatar
Yeah, my truck hasn't been rigged with the in-tank pump... still using the stock lift pump in stock location... 9psi @ idle, 6-7 while driving, and close to ZILCH at WOT.
The FASS setup I got is the 95/150gph. What's the difference between that and the 150/150?
I'm going to go ahead and do the install today.
Old Dec 24, 2006 | 05:21 PM
Tate's Avatar
95 has special filters only available from FASS dealers. The 150 series has filters you can get anywhere. I believe thats the major difference.
Old Dec 24, 2006 | 08:51 PM
NotMatt's Avatar
Thanks for the encouragement guys. It's all installed and rockin'. No leaks, about 18psi at idle, I'm fat and happy and ready for Christmas festivities (first I gotta take a shower to rid myself of diesel smell though... )
Old Dec 25, 2006 | 12:23 AM
Diesel-Dan's Avatar
I will have to double check...but i believe you can get the water sep. at any parts store.....the fuel filter was made just for the 95 Series FASS. I would suggest if you have any worries about the filter to stick a spare behind the seat.
You can run the 150 GPH units most of the time with no issue with the stock pick-up. If you get pressure fluctuations, or tons of noise coming from the FASS, this might be signs of the pick-up getting stopped up. Most of the trucks out there dont have issue. I am on 3 years on my 150 GPH now......
BUT you can't go wrong with the Draw Straw......never have an issue with the pick-up again.......
I hear Santa....im going to bed! haha.....Night yall and Merry Christmas!
Old Dec 28, 2006 | 02:57 PM
gitchyboy's Avatar
Not desiring to highjack, but have just stumbled across a lot of discussion about Draw Straws when using the in tank pump and a secondary pump.
I have the in tank pump, and have a holley pump that I had planned to put inline with the in tank pump. Can this still be done or am I better off with a draw straw and a holley pump alone?
Old Dec 28, 2006 | 04:07 PM
dodgediesel's Avatar
Just installed the draw tube from PDR Diesel on my 95/150. Pump noise level is down and I gained 1 LBS in pressure. To drop the tank and put in the draw tube was a snap and well worth the $45.00 spent on the draw tube. I ran my FASS 95/150 prior for 6 months with no issues. Love the FASS...
TNutcher
Sep 8, 2009 08:12 AM
abc4yew
18
Feb 27, 2009 10:44 AM
goodeyesniper75
Aug 7, 2006 03:17 PM
Reaper
Mar 27, 2006 03:10 PM
PsRumors
Mar 2, 2006 07:00 AM
