F.A.S.S question
Old Dec 27, 2006 | 06:38 PM
rollinsmoke's Avatar
F.A.S.S question
I was just wonderin , you guys using fass if the fuel line runs to the stock dodge filter or if you just do away with it and go straight to the I.P ? I'm sure you do away with the L P right?
Old Dec 27, 2006 | 06:41 PM
dodgediesel's Avatar
Mine is straight from the FASS pump w/filter's to the VP44. I've went to -35 with no problem!!! Love the FASS...
Old Dec 27, 2006 | 06:43 PM
Yea, that's what I was thinkin. Just use the filters on the FASS and go straight to the pump
Old Dec 27, 2006 | 06:47 PM
JAX's Avatar
JAX
I am using the factory water/fuel seperator still. Probably a little redundant to use it since the fass comes with an inline filter, but that's ok with me. I just have the pump though, not the whole "system". Not sure which one you are using. If the system (FASS II) comes with a water/fuel seperator that wires into the in dash sensor, then I guess it would be ok to bypass the factory unit. My .02
Old Dec 28, 2006 | 04:37 PM
cyric's Avatar
I ran mine through the stock filter/seperator at first but ended up having to bypass it later as the added fuel pressure pushed the drain valve open and leaked fuel.
Joe
Old Dec 28, 2006 | 05:50 PM
Olratlr's Avatar
Same here!
mkeanglorldo56
Nov 4, 2007 12:34 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
