F.A.S.S filter replacement......?????
Old Sep 13, 2005 | 10:06 AM
storx's Avatar
has anyone found a good source for replacement filters on the FASS system????????? to buy them from FASS they want like 100.00 for both.....and that outrageous..........i was just asking cause i cant make out the numbers on my filter from chipped paint on the filter "dont know hwo i did that".........i was planning on lookin it up but i dont have the numbers to go from....
Old Sep 13, 2005 | 11:17 AM
farmer dave's Avatar
There was a paper that came with the filter system that had a bunch of filters that could be used. It had Fleetguard, Wix, and Baldwin filters on it.
Old Sep 13, 2005 | 12:26 PM
storx's Avatar
truck had the FASS system before i bought it so that is not an option.....i have put 50,000 on myself on the filters no clue how many was put on before....
Old Sep 13, 2005 | 12:27 PM
Olratlr's Avatar
filters
Cim-Tek 70032
Fleetguard HF6338-HF6601- HF6610
Baldwin BT372-10 - BT372MPG
Old Sep 13, 2005 | 09:23 PM
storx's Avatar
Originally Posted by Olratlr
Cim-Tek 70032
so off hand anyone know which is the most quality one.... which is the cheapest????
Old Sep 14, 2005 | 07:15 AM
Many say that fleetgaurd is the best. Baldwin filters are ok I guess and they are cheaper. I have never heard of Cim-Tek filters so I don't know about those.
Old Sep 14, 2005 | 07:45 AM
PourinDiesel's Avatar
http://cgi.ebay.com/ebaymotors/F-A-S...spagenameZWD1V
Old Sep 14, 2005 | 12:24 PM
Olratlr's Avatar
Filters
Cimtek-$24.00
Flt - guard 6338 -$36.84
6601-$13.21 6610-$10.63
Baldwin- 372-10 $29.02
372-MPG- $63.88
Old Sep 14, 2005 | 04:00 PM
RowJ's Avatar
I guess it depends where you live.....but those prices sound way off. I buy Baldwins from my local Truck Parts Store.
I paid - $11.99 for a BT372-10 (10 Micron)
$12.99 for a BT372-MPG (3 Micron)
Have tried both...the 3 micron cost me no fuel pressure or power, so, why not use better filtration?
The 3 micron will last 50,000 miles +/-...the 10 micron has been run up to 100,000 miles by others.
Both are Baldwins. They make excellent filters, IMO!
RJ
Old Sep 14, 2005 | 04:03 PM
RowJ's Avatar
Why would you want to replace the Water Separator.....it is cleanable & reuseable! Just remove it...fill 1/2 way with gas, cover and shake it hard. I also suggest tapping it lightly - hard as possible, without denting it - to loosen up larger particles. I wrap it in a towel and tap it on my wooden work bench.
Refill with diesel (for easy restart) and reinstall!
I have done this twice...every 20,000 miles and gotten very little debris out of it either time.
RJ
Old Nov 2, 2010 | 11:04 AM
FASSAshley's Avatar
Replacemnt filters for the FASS systems can be bought directly through FASS
HD/150 Series: $22.00 per filter
Titanuim/95 Series : $20.00 per filter
Old Dec 28, 2010 | 07:37 PM
kerry.king's Avatar
Cim-Tek 70032
I just took these part numbers to napa and they had zero info on these. I ended up using a napa gold 3246 filter for now. Filters down to 16 microns, which is nay good. Called Cummins of rockymountain here in grand junction, they can get the fleetgaurd ff1527 filter, but dont keep it in stock. 11 dollars, but will only order them a dozen at a time. What a huge pain!!!
Old Dec 29, 2010 | 06:28 AM
These are some places that I have bought filters from before. If the parts dealer has to order a filter you might as well order it yourself and have it show up on your step.
http://www.usdieselparts.com/index.c...ummins-12v.cfm
http://www.enterpriseengine.com/display_part/18.php
http://www.blacksmokin.com/fass-filter-cross-references
Old Dec 29, 2010 | 06:51 AM
AH64ID's Avatar
Which FASS is it?
There are some much better options for filters, so post up what you have now and I'll make a good recommendation.
Old Dec 29, 2010 | 11:41 AM
kerry.king's Avatar
I've got the 95/95
