exhaust drone
Old Mar 18, 2005 | 04:59 PM
Twodiesels's Avatar
exhaust drone
I have a whinning noise at certain speeds/ rpm's when i push on the go pedal. As soon as i let off it goes away and then right back when I push throttle. Seems to do it ther worst at 50-55 mph. Is this the drone and what can I do about it?It just started doing this. I never noticed it before. Is it normal for it to all of a sudden appear.
Thank you
Old Mar 18, 2005 | 10:34 PM
KATOOM's Avatar
I didnt read in your signature that you have anything but stock exhaust so I dont think your hearing any drone. I did notice that you removed your silencer ring though. How long ago did you do that? Maybe your just hearing the turbo better.
Old Mar 18, 2005 | 10:43 PM
Forrest Nearing's Avatar
these engines are pretty loud. you get a lot of resonance from the exhaust downpipe. adding some sound deadener to the cab will make a HUGE difference. I consider it picking up where Dodge left off...
Forrest
Old Mar 21, 2005 | 06:06 PM
Twodiesels's Avatar
I think it is drone. Wheneverr i step on the go pedal it whines a little. Then as soon as I let off it goes away. Only at certainspeed/rpm's. I deleted the muffler when I did the silencer ring, but have not noticed it until now.
Thanks
Old Mar 21, 2005 | 07:31 PM
MtnCamper's Avatar
Does it only whine when the boost goes up?
Old Mar 21, 2005 | 07:44 PM
kevellis32's Avatar
I think i know what you are talking about, is it when your truck gets in overdrive and the engine does get much louder and your boost builds up.
Old Mar 25, 2005 | 01:49 PM
Twodiesels's Avatar
No it's not when boost builds up. If i am in drive and coasting with no throttle, Then I give it throttle this hum,whine/Wha,wha noise from about 30 miles an hour to 52 then stops. It is the loudest from 50-52 mph.As soon as i let off the throttle it stops and then when i apply even the slightest throttle, it will do it again.
Any ideas
Old Mar 25, 2005 | 08:11 PM
Ram2Pete's Avatar
Does this happen at a certain rpm instead of mph mine does it from about 1950-2100 whitch is about 75 with my 6 speed
Old Mar 25, 2005 | 11:29 PM
tenbrooks's Avatar
Try these http://dodgeram.org/tech/dsl/trouble...4v_trouble.htm
http://dodgeram.info/tsb/1999/09-04-99.htm
http://www.dodgeram.org/tech/dsl/tro.../isb_noise.htm
Old Mar 26, 2005 | 09:03 PM
tenbrooks's Avatar
T
Booger
Feb 19, 2006 07:37 AM
BIG MIKE
0
Feb 20, 2005 12:31 PM
OOPS
15
Nov 15, 2004 06:08 PM
dncoy
19
Jul 22, 2004 10:16 PM
NyukX3
Jul 16, 2004 04:28 AM
