Engine Oil Temperature Port?
Old Jul 8, 2007 | 03:32 AM
wcbcruzer's Avatar
I've got an Autometer oil temp. gauge sitting in my garage, so I might as well hook it up. Where can I hook it up to monitor engine oil temp.? I am already using the free port on top of the oil filter (next to the turbo feed line). Is there any other place?
Old Jul 8, 2007 | 02:40 PM
clutch1's Avatar
i was thinking there were some more ports on the side of the block next to the oil line to the injection pump.
Old Jul 9, 2007 | 07:58 PM
HOHN's Avatar
Don't you have a small pipe plug in a port on your oil filter mount? My truck has it. Just take out that 1/8NPT pipe plug and install your probe there.
jh
Old Jul 10, 2007 | 07:17 AM
drafalske's Avatar
He said he was already using that one. Its the only one I know of.
Old Jul 10, 2007 | 07:27 AM
scottsjeeprolet's Avatar
Well then put a Tee in there and use it for both.
Old Jul 10, 2007 | 07:49 AM
clutch1's Avatar
the line for the IP has a tee dosnt it. or you could pull a freeze plug on the bottom flange of the block tap it and use that and go directly to the pan.
jrs_dodge_diesel
Jun 23, 2010 10:43 AM
dodgediesel
Mar 8, 2007 09:21 PM
QWKRTNU
Sep 26, 2006 10:22 PM
rjm022
Feb 7, 2006 01:23 PM
