egt,s too high
Old Jul 10, 2007 | 07:34 AM
dustyman440's Avatar
Unhappy egt,s too high
my egts are running 750 to 850 just crusing not towing if i push the throttle hard ican get 1200 before i chicken out and back off i checked the innercooler for leaks , found nothing ,:any ideas on cooling things off
Old Jul 10, 2007 | 07:46 AM
clutch1's Avatar
that seems about normal.
Old Jul 10, 2007 | 08:29 AM
tony597fitter's Avatar
I agree with clutch, seems normal.
Cummins says you can run at 1250 degrees all day without worries. You could turn your boost elbow up a bit to around 30-32psi, to see if that helps.
tinknocker827
13
Dec 4, 2013 06:26 PM
TweetyBird
May 26, 2008 04:53 PM
bigwheels94
24
Aug 15, 2006 09:57 PM
cheff
Jan 23, 2006 09:44 AM
forcefed88
Oct 13, 2004 11:36 PM
