Engine mounted air compressor
Old Sep 18, 2005 | 11:22 AM
dover's Avatar
I have been told that there is an engine driven air comp. that can be mounted in front of the p/s pump. Is this true and if so were can I get one?
Thanks
Ben
Old Sep 18, 2005 | 11:46 AM
MnTom's Avatar
Send Haulin' a PM. He has the info you want.
Old Sep 18, 2005 | 12:28 PM
infidel's Avatar
The compressor that Cummins offers to mount at the PS pump won't fit in the Dodge application, there is just not enough room. You have to use a belt driven type that mounts on the passenger side of the engine.
Old Sep 19, 2005 | 01:03 PM
dover's Avatar
Were can I find a belt driven comp.?
Ben
Old Sep 19, 2005 | 01:50 PM
hotdram's Avatar
Try these guys out:
Kilby
Click the "products" button and drill down through there to the onboard air section.
~Rob
Old Sep 19, 2005 | 02:57 PM
JSX's Avatar
JSX
Originally Posted by hotdram
Try these guys out:
Kilby
~Rob
Kilby dosen't show one that fits a 12 valve. Anyone know what the difference is that makes it not fit a 12?
Old Sep 19, 2005 | 03:23 PM
Jambbii's Avatar
I dont think they make one for a 12v.
Old Sep 19, 2005 | 04:00 PM
jimk's Avatar
compressor
Bill, will a compressor off a 780 case backhoe work. It bolts on the top of the engine and it drives off a pulley behind the fan, I think. I thought I saw a kit that uses a york compressor and does the same thing. Or close to it. Just an idea Jim
Old Sep 19, 2005 | 04:16 PM
jfpointer's Avatar
I'm pretty sure it has to do with the pulley and belt configurations. For a long while he didn't have one available for 24 valves with a Nippondenso alternator, either, just Bosch.
Old Sep 19, 2005 | 04:53 PM
HOHN's Avatar
If you want a LOT of air, there's always a VMAC unit--- 75CFM!!!
Old Sep 19, 2005 | 07:39 PM
infidel's Avatar
Don't see why not as long as you can close the hood!
Old Sep 19, 2005 | 11:03 PM
Haulin_in_Dixie's Avatar
You can put the Cummins econ compressor on the truck, but trust me, you don't want to, expensive, much mods, cramped and crowded. Power steering pump from big truck, reset the pressure, moded motor mounts, and so on. You really don't want to do it. I have one but the mods were done with the engine out of the truck. And hope you never have to change the vp44, I am doing that now.
Old Sep 20, 2005 | 07:35 AM
2500CTD's Avatar
What is this VMAC you speak of
Old Sep 20, 2005 | 09:53 AM
signature600's Avatar
Nope...it has to do with no place to mount one. I talked with them a while back and he said there was no place he felt comfortable mounting a compressor on a 12v.
Chris
Old Sep 20, 2005 | 10:54 AM
HOHN's Avatar
http://www.vmac.ca/underhood/vr70.htm
Nothing else available for a CTD comes anywhere close to the air delivery.
EDIT: I was wrong, it's only a wimpy 70cfm, up to 175psi
