electric vacuum pump
Old Aug 24, 2006 | 05:14 AM
LanceD's Avatar
where can I get one? I know the powerjokes have them, but they have hydro brakes, will that pump pull enough vacuum to operate my brakes also?
Old Aug 24, 2006 | 07:35 AM
htgreen3's Avatar
I know that the 89 Ford 7.3 diesel that I had, had a belt driven vacuum pump. When I bought my first diesel, an 85 Chevy Suburban, they didn't have much of a vacuum pump, we also had an Airstream Trailer with vacuum acutated disk brakes. Need more vacuum, so I discovered that early GM 4 cyclinder cars had electric vacuum pumps to assist the engine vacuum. Found one, and built several tanks out of 4" PVC pipe. Plumbed it into the system and it worked great.
Old Aug 24, 2006 | 09:18 AM
Diesel-Dan's Avatar
Originally Posted by htgreen3
When I bought my first diesel, an 85 Chevy Suburban, they didn't have much of a vacuum pump....
Yeah.....I think the GM Vacuum pump was only on the engine to run the turbo wastegate.....
You have Vacuum booster on your 95???
Old Aug 24, 2006 | 09:55 AM
blackdiesel's Avatar
Registered
a dodge has a big enough pump on then to run vac/hyd. brakes, But if you need one, P.M. me I might have one laying around
Old Aug 24, 2006 | 10:01 AM
infidel's Avatar
I've read of several people with vacuum assisted brakes using an electric Ford pump rather than replace an expensive Dodge pump.
Never done it myself but apparently the pump is available at most autoparts for under $100.
Old Aug 24, 2006 | 10:34 AM
Diesel-Dan's Avatar
If you know someone with a SD...i can tell you where the pump is!!!
Old Aug 24, 2006 | 04:30 PM
LanceD's Avatar
we have a few ford bobtails here at work, I looked at it and it looks ideal except I don't know if it pulls enough vacuum to hold up to braking also. the fords have hydroboost brakes.
Old Aug 25, 2006 | 12:00 AM
RJF's Avatar
RJF
The larger Chevies also use hydroboost on their brake systems and I am pretty sure our Dodges do to.
Old Aug 25, 2006 | 02:35 AM
LanceD's Avatar
not mine, its vacuum. the hydro started in 97 I think
jimbo486
May 8, 2016 06:07 PM
Smokeman
13
Sep 23, 2014 12:56 PM
RoadDiesel
Oct 15, 2012 12:16 PM
country pride
Aug 14, 2010 08:18 PM
nvr-enuf
Apr 22, 2010 12:42 PM
