Electric fuel pressure gauge install on 01
I have the billet filter cover from Genos. Is it better to run it off the test port or the fitting on the cover? Where will I get the most accurate reading? My guage will be here any day. I want to do it right the first time...
This billet aluminum filter housing cap from Geno's is a really classy way to dress the engine up and tap for fuel pressure at the filter while leaving the test port alone.
Look HERE for more info on the cap.
FWIW, the Schrader valve test port at the VP44 inlet is a #4 SAE 45* flare fitting.....you can go to your local hydraulic fitting supplier to get the adaptor that will mate the SAE fitting to the NPT fitting on the sender.....but it is best NOT to mount the sender directly to the engine since the vibration will eventually destroy it. Instead, I would suggest that you mount it remotely with some hose and fittings.
FWIW, there is no advantage to tapping for FP from the test port compared to the Geno's filter housing cap.
I've got my electric sender on a piece of hose for vibration isolation.
Also, I've got it mounted PRE fuel filter at the tap on top of the filter. It's main use is to monitor the (factory) lift pump pressure.
I change fuel filters every 7500 miles at oil change. If I'm showing good pressure on the gauge, and the engine falls on it's face after a fill up, I know it's the fuel and not the lift pump. Hasn't happened yet...carry a spare filter anyway. (and lift pump)
Where are you guys hooking up these senders on the 01 trucks?
Any pictures?
Any pictures?
Properly valved and all?
Another place not mentioned is a tapped banjo on the bottom of the fuel cannister.
I don't have any pics, but I know there are a couple in the photo section of other members setups.
Moose10 maybe? Mopar1973man?
phox
Originally Posted by phox_mulder
Thinking about upgrading Top?
phox
phox
Just trying to help a friend with installation of his new gauge and I appreciate everybody's help
Lary, there are some pics of my sender mount in my gallery. As for where I tapped, right now I come off the bottom of the fuel filter housing as that's where the port is on the Wildcat line kit that I have. Before the Wildcast kit, I used a tapped banjo in the VP44 inlet.
I run a T-connection on the discharge side of the filter, from there I ran 18" of stainless braided - to a snuber valve - to the sending unit. Nice and steady pressure readings...no bouncing around from the injection pulses.
nrussell
Jul 23, 2008 08:58 PM
ado2b1
Jul 6, 2007 10:27 PM
8mpg
Jun 21, 2007 12:13 AM
streetsmoker
Feb 22, 2006 06:47 PM
doug
May 10, 2004 10:59 AM
