Egt question again
Old Nov 11, 2004 | 02:44 PM
Jambbii's Avatar
Red face Egt question again
Ok I know this is somewhat of a bandaid for my problem but my truck will peg the egt gauge really quick. Will a 18cm housing drop my egts quite a bit over my 16cm housing.? I dont care too much about driveability because I rarely need to get on go peddle around town. Twins are in the future, but it is quite a while away and I figured someone would trade me for my 12cm housing or my 16cm current one.
Thanks
Old Nov 11, 2004 | 03:16 PM
Unless your high EGT is due to being off the map (over 35 psi) the 18 cm housing will not help much. If you have no problems at low RPM but it's running hot up top it would be worth trying.
Old Nov 11, 2004 | 03:43 PM
Jambbii's Avatar
My problem is top end only when the peddle is on the floor. I just need something that is more I guess idiot proof right now. I was just doing some hill climbs and all of the excitement got to my head and I looked over at my egt guage and it was pegged. Like I said just a bandaid for a while unil I can get more boost somehow.
Old Nov 12, 2004 | 01:24 AM
got...DIESEL?'s Avatar
with them 40's and big fuel, you might have to back off that plate a little till you can get a bigger huffer on there, or a pair of em...... I had the same problem when I put my big injectors and dv's in. had to back the plate up quite a bit to save the top end barbcue show, or just not go to the top end. I'll have to be patient 'till the twins fly out of the sky. I'm really plagued tho, cuz I still have the little 12 hsg. Trying not to double buy anything ya know?? I would think, especially with the your tires, that an 18 would lag pretty bad......just a guess tho. My .02
Steven K
Jun 4, 2009 10:32 AM
b84u
Feb 20, 2006 01:04 PM
chuck3
Feb 1, 2005 07:47 AM
gunracer1
18
Nov 24, 2003 08:56 AM
Sean S
Nov 15, 2002 12:25 PM
