EGT gauge install question?
Old Sep 2, 2003 | 09:34 PM
chrismez's Avatar
I am getting my Isspro gauges installed on Friday. Does it matter if you install it in the Exhaust manifold or in the pipe after the turbo? Also how bad is it for the turbo if some shavings fall into the exhaust manifold? Will they just blow out of the motor or will it tear up my turbo? Thanks
Old Sep 2, 2003 | 09:37 PM
WTTD's Avatar
Re:EGT gauge install question?
Pre Turbo (exhaust manifold) is the only way to go on our engines. A few shavings will not hurt the exhaust side of the turbo. I always use a grease coated bit and then put a pen magnet in the hole to pick up the few shavings that do get by.
Chace
Old Sep 2, 2003 | 09:41 PM
chrismez's Avatar
Great thanks, I can't to see how these gauges look. White faces with chrome. I'll let the guy know about the grease anf magnet, if he doesn't already...
Old Sep 3, 2003 | 06:05 AM
k w's Avatar
k w
you can apply air while you are drilling also, this will eliminate most of the metal shavings.
Old Sep 3, 2003 | 06:13 AM
Shovelhead's Avatar
Administrator / Scooter Bum
I used my shop-vac with the crevis tool while drilling to catch most of the shavings.
Old Sep 3, 2003 | 07:25 AM
hellotbone's Avatar
As much as everyone says you don't have to pull the turbo and I maybe wrong but I do totally disagree with it and would highly recommend you do pull it.
Old Sep 3, 2003 | 08:43 AM
geer's Avatar
Grease the bit and use a magnet. You will have no problems.
Old Sep 3, 2003 | 10:13 AM
MLR1's Avatar
Go preturbo! I removed the turbo (not hard) it only takes 2 gaskets well worth the peace of mind. I have the autometer white face guages, they look great, i think you will like em. If you use the blue bulb covers they will almost match the factory lighting perfectly.
Old Sep 3, 2003 | 05:24 PM
Tiny's Avatar
Not to stir up any messes, but I drilled mine with no grease or other gadgets and goo. Prior to breaking through the wall of the manifold, take your air hose and shoot the shavings off, slowly push through the wall of the manifold and keep running drill while slowly pulling the bit out. Once out, take a pencil magnet and swirl around the manifold until it comes out clean, tap the hole, and thread in the probe. Finish the connections for the gauge, and fire er up.
Tiny
Old Sep 3, 2003 | 08:23 PM
WHIFF's Avatar
I never removed my turbo. Just used grease on the bit, a shop-vac, and a pencil magnet. Results were sweeeeet. If it's easy to pull the turbo, I don't see why not. Peace of mind is a wonderful thing.
jmccart
Mar 18, 2007 10:03 PM
Mountainmac
Nov 6, 2006 01:15 AM
PThree
Dec 5, 2004 09:29 AM
Boss
15
May 3, 2004 09:14 AM
pmtg
Dec 15, 2003 07:27 AM
