edge or tst?
Old Aug 2, 2003 | 01:09 AM
DynamicalyUnstable's Avatar
edge or tst?
So I can't decide if I should get the edge ez, or the tst pm2.
I was also considering going the next evel up. If i do, should I go with the edge comp or the tst pm3?
Which is better?
Old Aug 2, 2003 | 03:00 AM
PourinDiesel's Avatar
Re:edge or tst?
Both TST and Edge are great products.
But, if you go above the 65hp Edge EZ, your going to need a clutch or Auto tranny upgrade.
Also, if you buy the EZ now, later on you can stack it for additional power with the TST power max 3.
--Justin
Old Aug 2, 2003 | 04:04 PM
hellotbone's Avatar
Re:edge or tst?
I would get the TST if you plan on upgrading more down the road. That way there you can just up the power for alot less money.
Old Aug 2, 2003 | 04:53 PM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
Re:edge or tst?
Each of these products has their pros and cons:
Edge EZ
Pros - easy install, reliable, no need to pierce the pump wire.
Cons - If you decide you want more, you're selling it and upgrading to a major box
TST PM2
Pros - reliable, better bottom end power (IMHO), more power than the EZ (The PM2 is an 80 - 90 pony box), if you decide you want more, you buy the $100 remote and you've then got full functionality (9 level adjustability, 120 HP)
Cons - Little more money (PM2s sell for about 50 bucks more), you must pierce the pump wire
Rod
Old Aug 2, 2003 | 06:36 PM
Dr. Evil's Avatar
Re:edge or tst?
I dont mean to confuse the situation, but have you looked at the new Bluechip Diesel Box.....its supposed to be great and a really good price to boot. Have a look and see what u think.
http://www.bluechipdiesel.com/APB.htm
When I do get a box I will probably go with this one (I was previously leaning toward an edge comp)
Old Aug 2, 2003 | 08:16 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:edge or tst?
Buy the Edge Comp,.....don't pierce the wire,.....it acts just like an EZ ;D
Want more power?,....upgrade your drivetrain,....hookup the wire,.....120 ponies wake up,.....buy new BVDs after you hit the throttle on 5X5 the first time.
Old Aug 2, 2003 | 09:58 PM
Glenns 2ed's Avatar
Re:edge or tst?
I got the Puck for under 400 bucks --easy install too --does not void warrenty??--how come no body mentions the puck did i do a bad thing--????Glenn ???
Old Aug 2, 2003 | 10:13 PM
DarrellB's Avatar
Re:edge or tst?
Like Pourindiesel said, buy both, I did. ;D
DB
Old Aug 2, 2003 | 10:53 PM
Dr. Evil's Avatar
Re:edge or tst?
Glen,
Ive heard the Diablo Power Puck is actually pretty good...more so in increased milage than huge performance gains. As far as I know they do not void warranty either. As a matter of fact there is a DC dealer near me that sells and installs them. I guess my point is that there are other boxes, such as the Diablo, the Van Akken, the Bluechip etc. Although its hard to deny the all around great performance of the Edge products - seems like most everyone is running an EZ or a Comp. Just another viewpoint and something else to confuse the situation. ;D
Old Aug 3, 2003 | 12:59 PM
rich's Avatar
Re:edge or tst?
I ve had the puck was quite happy with it . now i have the tst 2 and now i cant find enough peaople to blow by when i'm loaded. The only thing i do not like about the tst is that does not help in low rpm range it doesnt kick in until about 1800. that will be fixed with injectors tho. I have not ran any of the ez products tho. my .02
mjpalmer
May 19, 2005 11:34 AM
rockjeep73
Mar 25, 2005 03:34 AM
WhiteSport600
Dec 23, 2004 09:59 AM
BCobb
Jul 11, 2004 01:49 PM
Zino
Aug 15, 2003 10:14 PM
