Edge Juice...boost #'s?
sounds like you found it. you wont be acheiving anymore without freeing up the rest of the system. go make a run without the filter and box on. putting a larger exhaust on will help out many areas. regardless of whatever is reading the pressure, that turbo doesnt do much past 35-36 psi. its just too small. like i said, i think youre problem is solved now. next, think about freeing up the intake and exhaust and the numbers will come.
jeremy
jeremy
I'm guessing then that I was wrong and yours was set to the right year,I just thought that maybe I was not the only one to have done that,with it set to year model 2000 mine only claimed to get to 25 psi also,but once I set it to 01 the thing could all the sudden get to 35 psi.....if you aint checked that you'll be working on getting boost for quite some time
MrSuzuki
Aug 25, 2009 07:22 AM
razor6
22
Jan 20, 2006 03:43 PM
ataboy9026
Dec 28, 2005 05:06 PM
djcheez
Oct 15, 2005 04:13 PM
Anybody got a J hook laying around.
