Edge Juice Boost??
Old Mar 4, 2007 | 09:19 PM
stroker4501's Avatar
Edge Juice Boost??
I can only get 28 psi max on my attitude monitor. I got the hot juice power level 6 and I put the elbow on that came with the edge juice. should i get more or should i buy a adjustable elbow? thanks
Old Mar 4, 2007 | 09:23 PM
xOmertAx's Avatar
make sure it doesnt defuel at 28. i think your stock turbo can put out about 34 safely. any more and you might have probs. check your settings and see what the boost limit is on your juice
Old Mar 4, 2007 | 09:26 PM
sluggo42's Avatar
Originally Posted by xOmertAx
make sure it doesnt defuel at 28. i think your stock turbo can put out about 34 safely. any more and you might have probs. check you settings and see what the boost limit is on your juice
I'm getting up to 34 on #5. Maybe you have a leak?
Old Mar 4, 2007 | 09:28 PM
jta's Avatar
jta
I have a turnbuckle and have seen 32psi on mine with out the wire tapped, you should be getting more than 28.
Old Mar 4, 2007 | 09:37 PM
Rammandan's Avatar
32 4 me too. and exhaust is stock untill u get to the bed. although intake is upgraded. What is an adjustable elbow?
Old Mar 4, 2007 | 11:24 PM
Where should i check for leaks? by the way its preset at 45psi out the box i havent touched it yet. an adjustable boost elbow is the copper fitting that goes from turbo housing to the wastgate. it has a set screw to adjust how much air goes through it.mario
Old Mar 5, 2007 | 01:49 AM
Big Blue24's Avatar
I could only get 30 psi out of mine for the last week or so that it has been installed and now I can get about 33 with the addition of my RV injectors. I think it is an altitude thing, here in Provo, I'm at 4500', whats your elevation there in Cheyenne? I thought there was something wrong with mine since I could only get 29 psi on the street and 30 on a long 8% WOT grade on the highway. These other guys are all under 2000' elevation with the bigger boost numbers. Buy those cheap injectors on ebay from Pensicola Diesel, RV's for $262 shipped and then you will make more boost. I just did a 1/4 mile run tonight and I finally hit 1280* on the pyro at about 80 MPH, right near the end of my run, so they are definately towable with the Juice. Now I wish I had bigger sticks!
Old Mar 5, 2007 | 11:07 AM
Big blue elevation is about 5,500 thats probably why. i plugged my wastegate and i still have nothing same boost i think i spools quicker.
MrSuzuki
Aug 25, 2009 07:22 AM
razor6
22
Jan 20, 2006 03:43 PM
ataboy9026
Dec 28, 2005 05:06 PM
djcheez
Oct 15, 2005 04:13 PM
