Edge EZ and Boost
Old Jan 17, 2006 | 04:18 PM
crobtex's Avatar
Edge EZ and Boost
I'm running the EZ WITH the boost elbow. Is there any way to get the EZ to kick in below 10 psi of boost? Once I hit 10 psi, the EZ is very apparent, but I want something that will kick in almost instantly.
Old Jan 17, 2006 | 04:23 PM
BigBlue's Avatar
I've heard that the Van Aken has a better bottom end than the ez. You ever figure out that stumble? Hope the 275's are working alright for ya.
Old Jan 17, 2006 | 06:04 PM
graphitecumnz's Avatar
order the Smarty programmer...
Old Jan 17, 2006 | 06:28 PM
Charlie8301's Avatar
The catcher/smarty will fuel like you want it
Old Jan 17, 2006 | 06:33 PM
Austin'sDodge's Avatar
My Van Aaken is noticable from the get go. I don't know if you have an intake but my Bhaf helped bring boost much quicker, evn over the K/n w/cutout box.
Sorry, see now that you have a Quad intake.
Old Jan 17, 2006 | 06:52 PM
crobtex's Avatar
Tyler, the 275's fixed the stumble. The old injectors didn't look too bad, but I guess they were worn out. Probably see you Sunday.......
Unless someone wants to trade their VA or Smarty even for the EZ, I need to figure out something else.
The Quad box does make it spool much faster, but not fast enough. It hits de-fuel so fast, I just barely get started and have to shift to 3rd.
Old Jan 17, 2006 | 11:14 PM
BigBlue's Avatar
When did you test a quad box?
Old Jan 18, 2006 | 05:46 AM
crobtex's Avatar
Quad Air Box......
Old Jan 18, 2006 | 12:50 PM
RowJ's Avatar
Trust me, you would not be happy if it did kick in earlier!
Set on High, you would have lots of fuel with no air, and a lot more smoke than you are getting now! Your already getting 67% (i think) added fueling at 0 boost. Any more would not do anything for you, IMO.
The smarty ECM Programer will give you more responsiveness at low boost, with actually less smoke than the EZ. (this based on my expirience with the MAD ECM). AND, no defueling!
I don't know how Marco does it, but he's very clever!
Wait till I get mine and your welcome to try it and see for yourself!
RJ
Old Jan 18, 2006 | 01:28 PM
Gotlift01's Avatar
So do you guys know if the Smarty is going to be stackable with the COMP??? I haven't had time to read all the posts about it and am curious cuz if so I'm SOLD!!!
~Nick
Old Jan 18, 2006 | 02:09 PM
RowJ's Avatar
Nick,
YES! There are basically 4 different settings... each of which comes w/ or w/o timing (see #2 thru #9 below).
If your box already adds timing (like your Comp), you go with the non timing setting of your choice!
SW# 0 : Half power .
SW# 1 : Fuel Saver
SW# 2 : Only Fuel and Boost
SW# 3 : Like # 2 + timing
SW# 4 : “Soft” CaTCHER
SW# 5 : Like # 4 + Timing
SW# 6 : Mild CaTCHER
SW# 7 : Like # 6 + Timing
SW# 8 : CaTCHER no timing
SW # 9 : CaTCHER with Timing
So you would want either #2, #4, #6, or #8.
#0 & #1 are ecomomy setting for those that want them.
RJ
Old Jan 18, 2006 | 06:49 PM
Gotlift01's Avatar
Originally Posted by rjohnson
Nick,
SW# 1 : Fuel Saver
RJ
AWESOME!!!!!!!!!!!!!!!! I am gonna get one of them bad boys when they come out!! Thanks man that's good news!!
~Nick
hotrod929
Dec 27, 2006 11:10 PM
dodgediesel
14
Dec 14, 2006 09:54 AM
razor6
22
Jan 20, 2006 03:43 PM
ataboy9026
Dec 28, 2005 05:06 PM
