edge ez
Old Jun 30, 2003 | 05:46 PM
tlampman's Avatar
edge ez
If I want to just add the ez edge with 65 hp, do I need to do my tranny? I pull an 11,000 lbs. gn. trailer
Old Jun 30, 2003 | 06:05 PM
Carnage's Avatar
Re:edge ez
get trans gauge. So on the long uphills you don't over heat your trans<br><br>also while your doing gauges add a Exhaust temp. so you don't melt the exhaust. keep the exhaust under 1300
Old Jun 30, 2003 | 07:34 PM
chuck3's Avatar
Re:edge ez
What are you driving? year, etc?
Old Jun 30, 2003 | 07:40 PM
DPG's Avatar
DPG
Re:edge ez
tlampman: IF you don't have a heavy right foot, your stock auto tranny ought to last quite a while. When you experience that power (like I did this spring when I added my EZ) you will probably want to use it. I already have the DTT tranny, so I don't have to worry about a little extra HP. With a stock tranny, you may well find that you will need to upgrade eventually. A friend of my with a 200l.5 CTD with the stock auto added an EZ, and it was about 3 months before he started slipping. He now has the ATS TC and VB and is once again a happy camper.<br><br>Hope that this helps.<br><br>DeWain
Old Jun 30, 2003 | 08:45 PM
oldroy's Avatar
Re:edge ez
I just put an edge ez on my truck, sure woke rattler up, but it will also slip my clutch at will while towing my 5er. lots of torque at low end (1600-1900 rpm) with ez!!<br>Get gages!!!!!!!!
Old Jun 30, 2003 | 09:21 PM
98rammer's Avatar
Re:edge ez
if it's an auto, up the line pressures.<br><br>Tom
jwhip
28
May 29, 2005 11:32 AM
rockjeep73
Mar 25, 2005 03:34 AM
Hoss
13
Jun 18, 2004 06:14 PM
powerwagon440
Jan 20, 2003 08:50 PM
