Edge Comp transfer problem
Old Apr 28, 2009 | 07:33 PM
accordivan's Avatar
I'm trying to transfer my Edge Comp from my wrecked 98.5 to the 2000 but the 2000 has the newer flat data liink plug whereas my Comp has the older triangular one. Anyone know where I can get an adaptor plug?
Old Apr 28, 2009 | 08:08 PM
HotRodTodd's Avatar
Does the harness unplug from your comp box? If yes, you can order a newer harness. If no, then you need a new comp, or you may be able to use the older style sensors or possibly splice the connections in.
Old Apr 28, 2009 | 09:48 PM
blacksmoke99's Avatar
I'll buy it from you!
Old Apr 28, 2009 | 10:37 PM
67HotRod's Avatar
Contact edge and get the correct harness. Better off in the long run.
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
