Edge Comp question
Old Dec 24, 2004 | 02:08 AM
cummins dsl's Avatar
Edge Comp question
Having a problem under heavy acceleration the truck has a studder with the box on. With the box off there is no problem. Does anyone have any idea what this is and how to fix it?
Engine codes: P 0500, P 1693, P 0237
Any help would be appreciated. Thanks.
Old Dec 24, 2004 | 05:43 AM
Clint's Avatar
P0500 Vehicle Speed Sensor 1 Circuit, or No Vehicle Speed Reference Signal 1
P0237 Turbocharger Boost Pressure Sensor Low
1693 ECM Error (my truck set this code with a bad CKP sensor, a generic code for PCM and ECM not communicating from reading the forums)
Codes https://www.dieseltruckresource.com/...n&onlynewfaq=1
I had to search for the P1693
Clint
Old Dec 24, 2004 | 10:03 AM
mooseman's Avatar
check all your connections. Mine stumbled on the first test drive after installing the comp. I redone all the connections and have not had a problem ever since with codes or stumbling.
mooseman
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
