Edge comp Question
Old Jan 28, 2007 | 07:00 PM
GoldGoat's Avatar
Edge comp Question
I have had an edge comp on my truck for about a year. The pump wire is tapped but what I was wondering what my egt's should look like pre-turbo I read on one thread that on 5x5 there egts would hit around 1500 deg and another question should my truck smoke alot more on 5x5 compared to 3x5 just wonderin any help.
Old Jan 28, 2007 | 07:16 PM
Clunk's Avatar
Mine hits 1250-1300 F but I have a 14cm exhaust housing and 4" exhaust.
At a 50 mph punch, 5X5 smokes more than 3X3.
Do you have fuel pressure & pyro gauges?
Old Jan 28, 2007 | 07:23 PM
GoldGoat's Avatar
yeah I have the commander gauge the max I can make it hit is only 1000 deg do you think that my box is messed up or that this is normal what kind of boost do you turn the most ive seen is 30 psi
Old Jan 28, 2007 | 07:44 PM
Clunk's Avatar
I make 36psi. Do you think your commander might be de-fueling your pump at an exhaust temp of 1000 F like the Edge Attitude?
Mine started surging at WOT until I soldered my pump wire on.
Old Jan 28, 2007 | 07:59 PM
GoldGoat's Avatar
the commander, I have the defuel setting turned off my truck does put out alot more smoke from 3x3 to 5x5. level 3x3 smokes a little but 5x5 smokes quit a bit do you have a mechanical boost gauge or is it tapped to the map sensor. What would happen if I tapped the wrong pump wire
Old Jan 28, 2007 | 08:13 PM
Clunk's Avatar
I have a mechanical boost gauge. A wrong tapped wire won't give any power improvement as found out in another post.
Is your pyro tapped like this?
Old Jan 28, 2007 | 08:20 PM
GoldGoat's Avatar
no mine is tapped between 4 and 5 cylinder. Do you think where your truck is a ho that would make a little difference
Old Jan 28, 2007 | 08:39 PM
Clunk's Avatar
Where yours is installed may make a difference since I've read #6 gets fairly hot.
Yours gets more fuel through the injectors...HO's don't squirt as much. That's the 25hp difference between SO's and HO's with a Comp.
Old Jan 28, 2007 | 08:42 PM
tx_2500's Avatar
you might not be getting proper readings on your EGT's. all of edges literature tells you to tap about 2" from the turbo flange on the firewall side. and id say 98% of DTR'ers reccomend the same
Old Jan 28, 2007 | 08:54 PM
GoldGoat's Avatar
Well when the weather gets warmer I will tap it in front of the turbo and see what I read hopefully thats what the problem is.
Old Jan 28, 2007 | 09:03 PM
Clunk's Avatar
Thumbs up
Some folks including Mack Diesel looks at temps after the turbo...900F max. but they're not hot rodded like our Cummins.
Old Jan 28, 2007 | 09:07 PM
GoldGoat's Avatar
I hope thats what the problem is. I dont think I want to tap after the turbo there is like a 200 deg difference isnt there between pre and after turbo egt install.
Old Jan 28, 2007 | 09:13 PM
Clunk's Avatar
I agree with you 100%.
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
