EDGE comp install
Old Apr 25, 2006 | 04:15 PM
sosborn's Avatar
EDGE comp install
I have an IP cover plate, but have not had the time to install it. Am I right in thinking I can plug in the MAP sensor plugs, the data com plug, and ground and run in level 1 and/or 2 without the IP splice?
I have not upgraded the tranny, so would it even be safe to run it on a higher level than that anyway, until I can upgrade?
Thanks,
Sam
Old Apr 25, 2006 | 04:48 PM
CTD2001's Avatar
You can do as you described above, this will make the comp act as an EZ, with just timing only. Once you get tranny upgrades or feel comfortable taping the wire with the stock trans, just install the new pump cover and hook up the gray wire and then you will be all set. When my IP crapped out on me, i ran the comp the way u described for a while untill my IP got replaced
Old Apr 25, 2006 | 05:30 PM
BlackCloud#2's Avatar
Edge Comp
When I put my comp in I didn't have any troubles without splicing the fuel pump wire. Also you have three stages and can control the fuel supply....if you want to be pc you have 15 stages to that w/o the splice.....my 02 ran great on stage 3 but if you find someone who says what stage is the best for fuel milage let me know!!!!
Old Apr 25, 2006 | 07:46 PM
sosborn's Avatar
Thanks for the posts guys. I plugged it in as described (ground, map, and data com) and drove around for a while. Kept it level 1 and 2 and played around with the sub menu a bit. I didn't really notice a big difference, but then I didn't step on it either. Would I have to in order to notice a change? I also didn't seem to get any smoke. Is is possible this thing is not hooked up properly?
Also, the led lights for level one and two are apparently out on my box. Are those replaceable, or am i SOL?
Thanks,
Sam
Old Apr 25, 2006 | 08:04 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Thanks,
Sam
If the Pump wire isn't connected, Put it on level 5X5.
It's like an EZ on it's highest setting.
It will let the timing come in quicker.
Try unpluging the box at the harness & plugging it back in.
If the lights still don't work, you'll need to send the box back for repair.
Old Apr 25, 2006 | 08:35 PM
sosborn's Avatar
Any danger on 5x5 without having any other mods?
Thanks.
Old Apr 25, 2006 | 08:51 PM
taken5875's Avatar
if you tap the wire and are bone stock then i woud say yes but untaped i would say you will be fine the only thing 5x5 will do for you is smoke more the fuel comes on at a lower boost level. do you have a pyro?
Old Apr 25, 2006 | 08:55 PM
sosborn's Avatar
I have one, but haven't tapped the manifold yet; so it's not functional at the moment.
Sam
Old Apr 25, 2006 | 09:30 PM
CTD_Neil's Avatar
I have the first light out on mine also. I just figured it was loose because every once in the while it will start working.
Old Apr 26, 2006 | 07:34 AM
Clunk's Avatar
Thumbs up
Sometimes the LED's come on for mine and sometimes they don't...it does not hinder the performance though. I ran-run mine normally on 3x3 so's to keep the normal driving smoke down then a coupla quick button punches get me 5x5 if I want it.
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
