Edge Comp ???
Old May 19, 2005 | 01:13 PM
Mike D's Avatar
Edge Comp ???
Has anyone tested the wire going to the injector pump? I was wondering if any voltage comes from that wire? Any help would be great.
Old May 19, 2005 | 02:21 PM
Mike D's Avatar
OK, Could someone test the wire? Maybe someone who hasn't tapped the pump wire yet. I'm curious to see what that wire does to the solenoid. I would also like know if in fact there is a reading, does the reading change depending on what level is selected on the box. I might be able to test one this weekend, so if there is a reading it would be nice to compare numbers.
Old May 19, 2005 | 03:30 PM
Shovelhead's Avatar
Administrator / Scooter Bum
IIRC the older edge instructions stated that you could use a test light to verify there was voltage present on the pump wire if you didn't get the Huge power gains when you installed the Comp.
As for the variable voltage.....no clue.
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
