Edge comp
Old Apr 1, 2005 | 03:03 PM
shoe's Avatar
Edge comp
J ust got my edge comp in the mail, man there is not alot there. Looks easy anough. Is there anything special I should know befor I install it? hardest part looks like the pump wire.
Rob
Old Apr 1, 2005 | 03:07 PM
oscaroc's Avatar
pump wire is easy just follow instructions. Hardest part for me was figuring out a place to mount it
Old Apr 1, 2005 | 03:10 PM
smokindog's Avatar
Pump wire is easy only if you use the supplied connector. Mine is soldered and wrapped in heat shrink. I've heard of many problems with bad wire connections. Be careful.
Old Apr 1, 2005 | 03:14 PM
99 cummins's Avatar
Definately do not use the supplied wire tap for the pump. I made that mistake and it left me stranded out a state having to pay a Cummins dealer over $200 to put a new pump wire on and solder the connections. I even siliconed the connector thinking that woul seal it up. If I had it to do over again I would go with the Blue Chip Cover for this connection.
Old Apr 1, 2005 | 03:21 PM
4x4dually's Avatar
A trick to keep soldered connections from failing is to first clean them good with alcohol and a brush to get rid of the flux (liquid or paste). If you don't use flux, you ain't solderin' correclty in the first place! Then put a little bit of grease (doesn't matter what kind) on it and shrink tubing over it. This will squeeze a little extra grease out the ends and help keep the water out of the connection for years.
Another thing to keep in mind is to crimp or twist the copper wire conductors together before soldering. Don't just lay them next to each other and rely on the solder to hold them together and conduct all the current. Remember, solder is soft and not near as good of a conductor at the wire material. If you rely on solder to hold the wires together, there is no telling when they will come apart, but they will.
My $.02 Hope this helps somebody.
Old Apr 1, 2005 | 03:34 PM
Beast2B's Avatar
Along the lines of the pump connection, make sure you ground the box to the battery (I used the inner fender screw that ties directly to the battery ground). I chased an intermittent trouble for weeks that turned out to be that ground! Ditto on the Blue Chip cover, easy install and not intrusive to the stock wiring.
Old Apr 1, 2005 | 04:16 PM
CTD NUT's Avatar
These guys all have good advice.....something I would add, though. I see you have a FP gauge - watch it closely when the Comp is cranked up!.....A marginal lift pump will really show it's weakness with a tapped Comp. I would suggest a Scotty Smart fuel kit with the addition of the Comp.
Old Apr 1, 2005 | 04:48 PM
shoe's Avatar
thanks for all the input, where can i get some info on those blue chip covers?
Rob
Old Apr 1, 2005 | 05:00 PM
Bart Timothy's Avatar
The TST Grabber is the fastest and easiest way to hook to the pump wire, plus it leaves no evidence that the wire was even touched.
Old Apr 1, 2005 | 05:25 PM
shoe's Avatar
where do I get one?
Rob
Old Apr 1, 2005 | 05:52 PM
bws's Avatar
bws
tst[20.00] they have a web site but first do your fuel system...there are other qaulity splice pieces that can be obtained...i went the tst but am waiting cause i ordered the fass 2 and the scotty fuel system upgrade,not sure which one i'll use???
Old Apr 1, 2005 | 10:24 PM
mkrenn's Avatar
Diffinetly the cover is first choice
Solder is 2nd choice.
OH, BTW, have you checked you lift pump pressure?
I blew up my VP44 2 minutes after my install.
BE CAREFUL!!!!!!!!!!!
Old Apr 1, 2005 | 10:30 PM
Ram2Pete's Avatar
Did you get the standard or drag version and what have you done to the trans if it is stock you also might want to keep the box turned down
Old Apr 2, 2005 | 06:15 AM
shoe's Avatar
My trans is stock for now that is next on the list. My lift pump pressure is kind of low I think, at idle 12 and driving under boost it drops to 10 maybe 9 at full boost of 18 psi.
Rob
Old Apr 2, 2005 | 10:09 AM
Ram2Pete's Avatar
lift psi good but the comp will drag it lower i can pull mine to around 6 at WOT
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
