edge comp
edge comp
i have been having trouble with my edge comp. sometimes i have it on 5x5and it seems really quick and other times its on 5x5 and it seems sluggish. and it just started doing this about 2 weeks ago. any suggestions? thank you
mine did that just a few weeks ago. first thing check the pump wire, if you have a stealth plate check the connection to the probe, you may have to turn it in a little bit more, but dont turn it to much. also, that didnt fix mine. i ended up shearing off a key way in my pump, causing the timing to be off, that could be it also, i had to get a whole new pump. maybe it could be your map sensor, it could be alot. hope i could help.
make sure your tap wire doesn't ground out. mine did a month ago and didn't realize it til i had to change fuses and see smoke come off hte dipstick. a new injection is the result to that. stealth cover and a new pump make it run real well.
With the comp if the box works on the fourth stage why is it worse on the fifth. When I put it on the fourth I have much more smoke, and am faster. If the tap wire or ground wire is off then the forth stage shouldn't work?? Any suggestions??
lately when i turn the truck off and let it set is when mine is quiting. then if u unplug the power and plug it back in it workes(at the fuse). but it only quites when u let it set a long time(6-8hrs).u cant shut it off and turn it back on 10 min later and everything is fine. any suggestions? thank you
b/c you've got too much fuel on 5 with your setup...my truck is also quicker on 4 as opposed to 5. 5x5 just bogs the turbo and egts get nasty hot. As far as the comp not working if it is under warranty just send it back to EDGE and see if it is shot. I know I sent back 2 edge Ez's that quit working....Oh and it would help to pull your codes...
