Dyno Result using Smarty #3
Old Feb 18, 2007 | 10:06 AM
Tiger Rag's Avatar
Mike, new #3 shows some promise on that TQ #! I still think your truck has more in it. That thing is FAAAAAAAAAAAAAAAAAASSSSSSSSSSSSTTTTTTTTT!
Blue, my truck likes higher Smarty setting too (out of the hole) although peak hp was only like 4 hp difference between #4 and #8 with my latest dyno run yesterday.
Old Feb 18, 2007 | 10:11 AM
CTD_Neil's Avatar
MikeD, I have noticed similar results on the street with the Smarty and Comp. The power is higher overall without the smarty. I run the even SW's so I guess #2 would be comparable to your #3? I've lent my Smarty to a friend to try out. When I get it back I'll try SW #2. I just ordered new injectors and while talking to Doug at PDW he said to dyno withoput the smarty installed.
Old Feb 18, 2007 | 03:37 PM
graphitecumnz's Avatar
Good info Mike...
Old Feb 18, 2007 | 05:44 PM
dodgediesel's Avatar
Mike D, what were your EGT's hitting with that HTT turbo??
Old Feb 18, 2007 | 07:20 PM
Mike D's Avatar
To be honest with you I wasn't looking. I was looking at the rpm gauge more than anything.
I can tell you at the end of the 1/4 mile I'm at 1550.
Old Feb 18, 2007 | 08:48 PM
dzlfarmboy's Avatar
Thank's for the feed back,just curious what about someone with a biger 66mm charger on the dyno, i know with the smarty on 9 and 7 it lights way better then on 3 and 5 on the street and figured that on the dyno i would put better #s up if i got it lit faster i dunno i'd like to get some dyno time and find out
Old Feb 18, 2007 | 09:08 PM
Mike D's Avatar
That's a good question. I agree the higher numbered programs will lite the turbo quicker. What I think the problem for me was, too much fuel too early. I gained 4 tenths in the 1/4 running #3 and gained 3 mph through the traps..
Seems trucks with twins don't seem to mind the high Smarty numbers either.
I hope more people try #3 to see if it works for them.
Old Feb 18, 2007 | 10:39 PM
MSquare's Avatar
Mike,
Congrats on the 500, very nice. TST in a box, sitting in the back of my truck........
Old Feb 18, 2007 | 10:51 PM
Mike D's Avatar
MSquare,
Thanks man. TST makes a good fueling box for sure.
Old Feb 18, 2007 | 11:14 PM
bway1341's Avatar
Great numbers
Old Feb 18, 2007 | 11:55 PM
Ph4tty's Avatar
Tiger Rag- those are some nice numbers you've got there
Was that with comp and smarty?
Corrected 590 HP 1144 TQ
Uncorrected 615 HP 1192
Old Feb 19, 2007 | 08:43 AM
Tiger Rag's Avatar
Best #'s came off the triple stack. Smarty 8, Edge Comp on 5 doing the timing, and TST on 9. Didn't have time to make all the combinations I wanted....maybe a later dyno run. BTW, thanks for the compliment. Also, I was only 4 hp less with the Smarty on 4 with the other boxes the same.
MX429
44
Feb 16, 2008 08:35 AM
rogerL1961
Oct 3, 2007 11:07 PM
Mike D
Feb 16, 2004 12:57 PM
