Dyno Result using Smarty #3
Old Feb 17, 2007 | 09:41 PM
Mike D's Avatar
I thought I would post my results for anyone who has followed my threads about using #3 with a TST over the higher numbered Smarty programs.
The results were almost predictable in my mind as I've already seen the results at the track, but you never know when it comes to the "humbler"..
Previous results were 460/1000 torque with Smarty #7 and TST #9 (corrected)
Uncorrected number were 471/1017.
I went 507/1042 Smarty #3 and TST #9 (corrected)
Uncorrected numbers were 527/1069 if I remember right.
I would estimate it's about a solid 50HP difference between the 2 settings on my truck.
Old Feb 17, 2007 | 09:49 PM
hotdram's Avatar
Very nice numbers Mike.
~Rob
Old Feb 17, 2007 | 09:54 PM
dieselfan's Avatar
nice #'s Mike, thanks for following though with the testing. You were right.
Old Feb 17, 2007 | 09:55 PM
Ph4tty's Avatar
Nice run man. I knew you'd work it out and make it to the 500 club
Old Feb 17, 2007 | 09:56 PM
BigBlue's Avatar
Awesome man. I dynoed on #3 last time and it only did the numbers in my sig. Maybe my truck likes the better fueling of the smarty?
Old Feb 17, 2007 | 10:12 PM
Mike D's Avatar
Thanks guys! It does feel good to be in the 500HP club.
Tyler, How much boost are you pushing out of the 62?
Old Feb 17, 2007 | 10:16 PM
BigBlue's Avatar
I've got it gated to 40psi until I get the studs in. Once those are in I'm going to 50psi. The EGT's went up a LOT slower at 50psi than they do at 40. Not to mention I've still got a stream coming out of the stacks so I think some more boost and the water/meth and possibly some more timing I can hit 500hp.
Old Feb 17, 2007 | 10:28 PM
Mike D's Avatar
IMO I would try to set it at 50 psi spike and settle in at around 48.. I've heard 50 psi is about the limit on the turbo and a SO head gasket. I'm going to fab. up a drive pressure gauge to tell the tale on my 64.
Old Feb 17, 2007 | 10:30 PM
BigBlue's Avatar
That's what I was thinking. Once I get the studs in (hopefully tuesday or wednesday) I'm gonna crank the boost up and check drive pressures and then check them again with the water/meth. I have no pressure spikes with mine. Once it hits the wastegate it sits there. Must be the oversize wastegate doug put on there.
Old Feb 17, 2007 | 10:49 PM
Mike D's Avatar
Here's the dyno sheet.
Old Feb 17, 2007 | 11:44 PM
haloman's Avatar
Time to update the sig. Good numbers
Old Feb 18, 2007 | 01:16 AM
NoSeeUm's Avatar
Thanks Mike
Jim
Old Feb 18, 2007 | 01:36 AM
Ph4tty's Avatar
I love it- 500 hp from 2500-3100 Can't get much flatter on the hp curve.
The torque peak is a little later in the rpms compared to your 460 run isn't it?
Old Feb 18, 2007 | 07:18 AM
Mike D's Avatar
Old Feb 18, 2007 | 07:27 AM
Mike D's Avatar
You're right Ph4tty, I remember you saying last time if you can have the peak tq later in the rpm range it would be a over 500 hp run. The peak tq curve is a little fatter as well when compared to the 460 graph.
You remember me talking about the surge of power I was getting on the higher programs if I let out of the pedal? You can see it on the 460 graph, that was my peak hp.
