DV Question
Old Dec 2, 2005 | 11:37 AM
pullmaxdude's Avatar
Thumbs down DV Question
I am running 330 marine injectors with A #6 TST plate and staight 4". Should I consider a set of Delivery Valves as a next step, or should I be looking toward something else to gain hp???
Old Dec 2, 2005 | 11:41 AM
sorry about sig!!!!!
Old Dec 2, 2005 | 04:46 PM
mr T's Avatar
sure u could do that...and get the 4k gsks and bump ur timing
Old Dec 2, 2005 | 07:59 PM
Diesel-Dan's Avatar
OR.....Exhaust might be a better step......stock pipe is not going to cut it with that fuel........after that....sure! Get the Springs and Valves....they do help LOTS!!!!! Then its a turbo....and a clutch/tranny......and........aint it great!?
Old Dec 3, 2005 | 07:11 AM
Dangousity's Avatar
something wrong with your sig???
Dangousity
lets so pack sand togeth.... oh nevermind .. i got all i need in my boots.
Old Dec 3, 2005 | 11:06 AM
Fueling around's Avatar
Try a harder fueling plate (#10, #4, #100, #0) and GSK.
You'll be needing a turbo upgrade soon.
Old Dec 3, 2005 | 11:52 AM
Can the #6 plate be ground or do I need to get a new one????
I was told if I mess with the DVs I will cook the turbo! I just figure that since she has over 300k on her now that the darn thing has paid for her self many times over and at this point it is cheap entertainment
Old Dec 3, 2005 | 01:08 PM
halerazor's Avatar
i put a set of laser dv's in and had a small hp gain. the stock turbo is way too small. if i was you i would go with a turbo or a gsk kit. a gsk is the best mod you can do by far feels like it gives you 200hp
mkeanglorldo56
Nov 4, 2007 12:34 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
