p7100 pump missing
Old Apr 19, 2005 | 07:56 PM
masonic-dodge's Avatar
Question p7100 pump missing
A friend of mine has a 94 3500 2wd with a 160 pump and it will get a slight miss every now and again. He put my old 160 injectors and 131 DVs in it and it still has a miss. Its not all the time just some times.
Old Apr 19, 2005 | 09:54 PM
Fueling around's Avatar
Start with the aw shucks things
fuel return line
overflow valve
fuel heater (leak air)
fuel shut-off solenoid and control relay
No luck on the easy stuff then consider pulling the pump for a stand service job.
Old Apr 20, 2005 | 12:01 AM
dodgeman01's Avatar
I was given a loaner but from Cousin Billy at BRC Diesel and it ran great on his truck but on mine it missed and stumbles really bad. checked fuel pressure and everything is great. I'm still holding 30PSI and my timming is around 16* I'm kinda worried th epump is headed south but I also just blew up my stock pump last month wandering why the p-pump is always called the king of pumps when they can't support 400HP for very long
DM01
Old Apr 20, 2005 | 02:22 AM
Jambbii's Avatar
I had a miss when one of my injectors was leaking. It sounded somewhat choppy but ran ok. I was rinsing off some oil when some water got on the injector and I noticed some bubbling. Anyways the copper washer was bad. Put new ones on and that solved my problem.
Old Apr 20, 2005 | 09:05 AM
signature600's Avatar
DM01
Probably because at 400hp your only using about a 1/3 of the fuel the pump can put out
Chris
Old Apr 20, 2005 | 10:15 AM
gunracer1's Avatar
mine has 259k on the original 215 pump and is going strong. and it is well over 400 hp.
Old Apr 20, 2005 | 04:19 PM
dodgeman01's Avatar
Chris
Then I should still have a injection pump on my truck right?
DM01
Old Apr 20, 2005 | 06:05 PM
"Should", probably...but at 285K miles I "should" have an engine that doesn't puke a quart of oil out the dipstick tube every 100 miles, and still have a high RPM miss, pop, and white smoke problem, either.
Still don't know if it has major problems or just VERY amplified smaller ones .
Wanna trade trucks???
don'tgetyourpantiesinabunch,juststirringyouup,
Chris
Old Apr 20, 2005 | 08:04 PM
doodah's Avatar
I got a nice 180 pump I'll sell yah for $650 shiped!! Just sittin in the garage. stock, hasn't been modded! come out of a 98 auto
Old Apr 21, 2005 | 10:38 AM
The miss is coming from #1 cylinder, because from what he said that at the exhaust port at the exhaust manifold the temp is 40 degrees cooler when it starts missing.
Thanks for all your input.
CRIS
Old Apr 21, 2005 | 10:51 AM
Crack the injector line to the #1 injector and see if the engine sound changes...if it does, I think it's okay(well, to a point)...if it doesn't, something wrong with that injector.
OR
Move the injector to another cylinder...and see if the problem follows. If it does, bad injector, if it doesn't...bigger problems in the pump, or cylinder(maybe???)
HTH,
Chris
Old Apr 21, 2005 | 12:11 PM
Chris
I gave him my 160 injectors when I put DD4s in mine, mine are in his truck now and it still does it. He bought the truck new in 94 and they changed the pump back when it was new for the same reason and it still does it. It doesn't do it all the time, just some times.
Doodah
I wish I had the money because I want your pump bad, but I think I'd buy it from you off of that other site because its $50.00 cheaper over there Why are you wanting more from us then them?
CRIS
Old Apr 21, 2005 | 10:13 PM
doodah's Avatar
Honestly, I just want to sell it, and forgot what I put on for price over there! I will stand behind either price!lol
Old Apr 22, 2005 | 08:06 AM
I'm plumb out of ideas then, sorry.
I'll be changing my pump soon to a 913 to see if that helps my 2200-2500 RPM white smoke, missing and poping.
Probably won't though, just my luck.
Chris
Old Nov 29, 2005 | 07:02 PM
12valve's Avatar
advance your engine timing, and stretch the spring in the overflow valve, and you should have no poping and no white smoke at all...
ive done that in many many 2gen doge specially 94, 95
