Dually Conversion on SRW, then run 285 tires?
Old Jan 2, 2008 | 12:04 PM
Bobcat698's Avatar
How would one convert a SRW to a DRW but have the tires spaced out enough so that 285/75/16 tires will fit without rubbing together?
Thanks in advance!
Old Jan 2, 2008 | 12:19 PM
crucescrawler's Avatar
Visit www.wheeladapter.com they have some pretty good dually information, hope that helps...
BTW, I am the guy that bought Travis' truck...
Old Jan 2, 2008 | 12:36 PM
Bobcat698's Avatar
Thanks, been on the phone with them a bit now.
Why was that truck overheating?
Old Jan 2, 2008 | 12:45 PM
Havent pulled real heavy with it since, just been using my dads truck for the big stuff... I still have absolutely no idea what is wrong with it. It stays cooler now that its pretty cold out. Someone told me that my timing got shifted... I have heard all sorts of contradicting statements from people trying to help.
Old Jan 2, 2008 | 12:51 PM
Dodge12vKing's Avatar
I'm in the process of doing this, got the dually converted and have some 285/75's ready to run, just figuring out what size spacer.
Old Jan 2, 2008 | 01:06 PM
Bobcat698's Avatar
I've heard you need a 2" spacer, but then you have to double stack spacers..
Old Jan 2, 2008 | 01:57 PM
getblown5.9's Avatar
any machine shop can whip up some 2" spacers in a days time for a reasonable cost, but will the studs be long enough?
Old Jan 2, 2008 | 03:22 PM
97' CTD's Avatar
I got rims and tires 265/75-16 BFG All-terrians on 16" eagle 058's just delete the rear brakes and bolt em up PM if interested Brand new parts stickers still on tires!
Brandon
Old Jan 2, 2008 | 03:32 PM
haloman's Avatar
Brandon
delete the rear brakes? as in get rid of them? wouldn't that make the truck street-illegal?
Old Jan 2, 2008 | 03:50 PM
kas83's Avatar
I think this is going on a dedicated pulling truck so that won't really affect it much.
Old Jan 2, 2008 | 04:00 PM
97' CTD's Avatar
Brandon
Old Jan 2, 2008 | 05:01 PM
cumminsdriver635's Avatar
You can buy 2 inch spacers on ebay im pretty sure. I think 1.5 inch spacers will work fine, but you have to cut some off of the stock wheel studs in order for them to work right.
Eric
Old Jan 2, 2008 | 05:12 PM
Bobcat698's Avatar
Right, but brakes are required for street class NADM.
Old Jan 2, 2008 | 08:14 PM
Who says you cant have spacers, and brakes? Teddy Bear on here(Josh Land) has 1.5 inch spacers on his pulling truck with 265's, and there is plenty of room for 285's.
Eric
Old Jan 2, 2008 | 09:09 PM
Bobcat698's Avatar
Eric
Josh has a native dually. The axle in my truck is currently a SRW axle.
To run dual wheels you need a spacer so the dually wheel clears the axle, then another 2" spacer to run 285/75/16 tire, otherwise they'll rub.
