Drag Comp compared to TST PM3
Old Mar 16, 2008 | 12:40 PM
Redliner's Avatar
So i just got a PM3 installed into the truck. How come it dont feel like it makes as much power as the drag comp does? If I stack them the power is there though but what settings should I have them on if I stack the 2 of them????
Old Mar 16, 2008 | 06:26 PM
sleeper-sport's Avatar
That's because the drag comp does fueling and timing. The TST does fueling only and you will need to stack it with a timing box like an Edge EZ to see similar or better results. From what I've heard the box to beat is a TST comp (upgrade) stacked with a Edge EZ. The comp tune on the TST will fuel higher than the drag comp also 3600rpm instead of the drag comps 3200rpm.
Old Mar 16, 2008 | 07:38 PM
Redliner's Avatar
Ive tried the TST Smarty stack - gives great power but dont seem like as much as the Comp Smarty stack in the seat of your pants. Any suggestions?
Old Mar 16, 2008 | 07:42 PM
Fishin2Deep4U's Avatar
I always felt the TST/ EZ stack was much more powerful SOTP than the Drag Comp.
That said, the Drag Comp makes more power on the dyno in my truck.
Dave
Old Mar 16, 2008 | 07:52 PM
Big Blue24's Avatar
Try an Adrenaline/nothing stack. It makes great power and plays well when stacked with nothing. Worth every penny for most of us!
Old Mar 18, 2008 | 05:41 PM
One Stack's Avatar
has anyone stacked a TST and an edge drag together? and if so how did it work.
Old Mar 18, 2008 | 05:45 PM
AggieJustin's Avatar
That would be the same as the TST/EZ stack. You can only use one tap on the pump (which would have to be the TST), so you would only get the EZ functionality (timing/ecm fueling) from the Drag Comp and the TST fueling (via wire tap).
Old Mar 18, 2008 | 05:47 PM
Krob's Avatar
What about TST and XZT+? Whats are some other fuel only box?
Old Mar 18, 2008 | 05:54 PM
You can stack the TST with pretty much any other box that doesn't tap the wire.
If you stack it with something that does tap the wire, then you're basically limiting the other box to what it can do via other connections since the TST will control the VP through the wire tap.
IIRC, the XZT+ is like an EZ, so I would expect similar performance to the TST/EZ stack. The main difference would be in timing and low-boost fueling.
Old Mar 18, 2008 | 07:49 PM
One Stack's Avatar
what would be the hp output with this setup. Would it be the same or more or less ? because i am going to dyno them in april.
Thanks
Old Mar 19, 2008 | 04:21 AM
part time pulle's Avatar
Buy a REDLINE!!!!!!!!!
Old Mar 19, 2008 | 06:39 AM
Redliner's Avatar
I would but the street drivablity is not there from what Ive heard..... TST/Drag Comp (no tap) stacked fine for me. Didnt seem like no more power than what just the drag comp has. Thats why I started this thread. TST/Smarty was about the same as TST/Drag Comp Stack.... Going to dyno on the 29th at TNT so Ill let you know what for numbers it makes.....as long as it stays together
Old Mar 19, 2008 | 10:10 AM
bama's Avatar
something else to keep in mind is the problems that a great deal of folks are having with timing studder.this seems to be worse on 01 and 02 models,and usually in colder climates.....ive had two 02 models and fought it with both of them.........thats why i run a tst comp,no extra timing,no studder.......bama
Old Mar 20, 2008 | 12:27 PM
NoSeeUm's Avatar
That is what I am running and I really like it. I have no clue about dyno numbers, but it is a very nice stack for a dailey driver with the TST set at PL4-5. Does not smoke much. In my case just some grey haze.
Feature for feature, if I was buying all new, I think I would just get the Adrenaline and be done with it. As it is, the TST is extremely reliable so I just can't see making the switch. I run the XZT+ mostly for a little more timing, the recent the high idle feature and Quad's very high customer involvement.
From what I can tell the XZT+ adds zero to the SOP meter all by itself. The TST fuels fairly hard and just about anytime I am running without it feels like a power vacuum. So it is hard to compare evenly / fairly. I do tow with the XZT+ only though.
Jim
Awall
26
Jan 9, 2007 02:48 PM
dodgediesel
24
Oct 25, 2006 04:40 PM
blackdiesel
34
Aug 2, 2006 08:41 PM
rockjeep73
Mar 25, 2005 03:34 AM
joefarmer
20
Dec 11, 2004 05:25 AM
