double purpose boost gauge?
Old Dec 15, 2005 | 06:14 PM
greenworks's Avatar
I have been tring to not have 4 gauges in my truck being I want to run a exhaust brake pressure gauge, then it hit me I could use the same gauge as a boost gauge, being the exhaust brake can only come on when the pedal is a zero being the microswitch will overirde the brake. If a guy ran a one way valve in each line from the manifold and the brake the pressure would go through the valve and register pressure while closing the other one with no pressure.
My only thought is what kind of pressure will a open exhaust with a resonator make when running WOT.Being that would blow my idea out the window.
Anybody tried this or run like this, or am I on crack ??
Old Dec 15, 2005 | 07:52 PM
infidel's Avatar
I did an install like this on a '98. Used a two way electric valve that originally used to switch between left and right fuel tanks. These are easily available, two inlets, one outlet. The exhaust brake switch toggled the valve back and forth to a single gauge.
Your back pressure can't exceed the valve spring rating--- 60 psi gauge will do.
Need to use copper or stainless tubing for the first couple of feet off the exhaust before switching to nylon tubing.
Old Dec 15, 2005 | 08:53 PM
greenworks's Avatar
being it is mechanical I can't ue a switch I can only try to block the pressure with one way valves, the way I am thinking is that I will have boost when on the throttle and pressure when on the brake without having to touch anything to switch between the two.
Old Dec 15, 2005 | 09:21 PM
Dr. Evil's Avatar
Greenworks,
How about this gauge with 2 senders??:
http://www.egauges.com/vdo_mult.asp?...yber_Red&Cart=
Old Dec 15, 2005 | 09:26 PM
Big Deezul's Avatar
Originally Posted by Dr. Evil
Greenworks,
now thats trick!
Old Dec 15, 2005 | 09:32 PM
greenworks's Avatar
that could work alright but i have the autometer z series pyro boost and fp already I am just trying to figure out how to rig the boost guage as a dual purpose unit, it will probably cost me more I bet to do it than it would to run a brake gauge with a pod.
thanks for the link dr
Old Dec 15, 2005 | 09:45 PM
Dr. Evil's Avatar
figured you want to use an existing guage...just wanted to throw it out there in case you cant make it work.
Old Dec 16, 2005 | 08:01 AM
swank's Avatar
two, one way valves? won't the pressure get trapped in between? leaving the gauge at the highest reading. a guy i know sells a product that's designed for that purpose. i think it's only about $20 or something. shoot me a pm and i can get you his # if you're interested.
dave
Old Dec 16, 2005 | 08:46 AM
greenworks's Avatar
Bingo!... problem your right It will read the highest pressure it sees then stay there, drat I'lll pm you anyway to see it his product will work.
Thanks
Old Dec 16, 2005 | 12:11 PM
Homestead's Avatar
If I'm not mistaken, Westach makes a dual boost guage.
Jeff
Old Dec 16, 2005 | 05:59 PM
swank's Avatar
yeah, but it sure is cool to see one needle doing two jobs.
unioncreek
Jul 11, 2013 06:33 PM
hamilton71801
17
Sep 9, 2007 01:44 PM
charger 69
Jun 4, 2007 02:09 AM
bthomas
Nov 17, 2006 12:28 PM
Mexstan
Sep 6, 2003 06:55 PM
