Dodgezilla
Czechdiesel -- Parvenu currently runs the EZ/275 combo with his DZ. I run an Edge Comp without the pump wire attached (like an EZ), and 275's. Both of us are running the 14cm2 exhaut housing, although Parvenu ran a 12cm2 stock housing for awhile.
Niether of us have a lot of lag, although the turbo could certainly support more fueling. Like he said, though, we both have 5600 trannies, so we drive "around" whatever lag there is. Whatever anyone else says, even though you may not need anything but a stock HX35 at 325 hp, the difference is very noticeable for both of us, especially pulling loads, on grades at high speeds, and when the boost hits +20.
Hope that helps. Parvenu can chime in here if he's around.
[QUOTE]Originally posted by Tartarus
so we drive "around" whatever lag there is. QUOTE]
Thanks, but what about "drive around the lag with auto and 3.55 rear end" ?
Do you or Parvenu plan to go with bigger injector later on ? What kind of toys you haul for off road play ?
cd
cd
JaMan
Mar 7, 2004 05:24 PM
