View Poll Results: Do your 315's rub with 16x8's and a 2" spacer?
Yes
17
58.62%
No
41.38%
Voters: 29. You may not vote on this poll
Do your 315's rub with 16X8's and a 2" spacer?
Old Oct 9, 2006 | 06:47 PM
GatorRam's Avatar
Thank you to everybody else. Please keep the info coming.
Adam
Old Oct 9, 2006 | 07:49 PM
GSP's Avatar
GSP
Gator Ram,
I beg to differ with you .
I think if you look up the specs on that tire size you will see a a 9.5"-10" rim is recommended. An 8" rim pulls the side walls in too far, Causeing center bulge and center wear on the tire. This is a fact from experience.
Sorry to hurt your feelings.
I recommend you running the proper size tires on the proper size rims. You do what ever you want. Spend $200- $250+ apiece on tires and run them on the incorrect size rims is your privelage. Run those 35x12.50x16 tires on 8" wide rims and observer how they wear out.
And you are the one that mentioned useing wheel spacers. Enough said.
Good Luck to you
Old Oct 9, 2006 | 08:34 PM
SuperDave4x4's Avatar
They rub the back of the fender at full lock a hair, but only when the truck is flexed a little. Put it this way I've taken my truck off road and put it through the paces with my front and rear sway bars disconnected and I didn't rip my fender wells out nor did I ever come close to rubbing the control arms.
Old Oct 9, 2006 | 09:02 PM
Scramblinman's Avatar
Originally Posted by GSP
Gator Ram,
Good Luck to you
<edit to remove personal attack>
Why don't you tell us what Toyo recommends: Toyo Tires - Open Country M/T
My truck had 315/75R16s on 8" rims on it when I bought it and while the tires were worn out, they were worn evenly. They have been replaced with a set of Toyo Open Country M/Ts of the same size. And I have run 35x12.5 tires on 8" rims on various rigs in the past with similar results. So MY experience is contrary to your own. Perhaps you just like to run around with overinflated tires. Sorry to hurt your feelings.
Not only that, but there are probably literally millions of offroaders running 35x12.5 tires on 8" rims without undue wear or any other ill effects. The narrower rim is more protected and less likely to suffer damage to the bead area, too. The looking too cheap comment was just sheer ignorance.
Old Oct 9, 2006 | 09:14 PM
Beeram305's Avatar
On my 2000 the tires rub at a little past 1.75 turns, usually its enough for me to get away with it. Once in a while I will get caught and have to back up or something, not a big deal.
Where can you get these 2" spacers anyway? I just put fender flares on, and a 2" spacer would fill it up nice.
Old Oct 9, 2006 | 09:23 PM
GSP's Avatar
GSP
Originally Posted by Scramblinman
<edit to remove personal attack> Why don't you tell us what Toyo recommends: Toyo Tires - Open Country M/T
Old Oct 9, 2006 | 09:40 PM
Originally Posted by CASMOKIN
Agreed! I am running 315's up front on my stock wheels temporarly, while I save up some coin for new 35/18's.( lost mine in my wreck ) What a pain in the Edit. I have to park at the back of any parking lot just to be able to pull out of a parking space. That rub is worse than nails on a chalkboard. I dont recomend it. Ive had no prob. in the past with my 35/12.5/18's tho.
Tom
A 35x12.5 should be a 35x12.5 regardless of rim diameter. How wide were the 18" rims and much backspacing did they have?
Old Oct 9, 2006 | 10:02 PM
bnold's Avatar
I don't know whats going on with this forum the past couple days!! Between the overweight scale thread and this one with too many experts with no expertise!! Kinda Funny but really not
Old Oct 10, 2006 | 05:05 PM
GatorRam's Avatar
Thanks for ruining this thread.......what a great help you've been there guy.
Old Oct 10, 2006 | 05:27 PM
Shovelhead's Avatar
Administrator / Scooter Bum
That's too much editing for one thread.
Keep it civil or this one's done.
Old Oct 10, 2006 | 05:55 PM
JAX's Avatar
JAX
Personally, I prefer running a 35" tire on an 8" rim when off roading. When you air down, the narrower rim helps to keep the beads tight at low air situations. Plus the added benefit of an even wider footprint
Old Oct 10, 2006 | 06:02 PM
Mglass1045's Avatar
What brand tires are they?
Old Oct 10, 2006 | 08:21 PM
Dr. Evil's Avatar
Are you running 315's on 8 inch wheels?? on the dodge or another vehicle?
Old Oct 10, 2006 | 08:22 PM
Dr. Evil's Avatar
Pays buy the hour doesnt it???
Thanks Ed.
Old Oct 10, 2006 | 08:58 PM
tontof18's Avatar
anyone trying to get rid of after market 16X8 rims, please send pics to tontof18@yahoo.com and label it rim pics so I don't think it is spam.
