Differential cover with drain plug
Old Sep 27, 2005 | 09:10 PM
flynhigh205's Avatar
Does ne one other than Mag-Hy-Tec and that PLM company make one for my Dodge Ram 2500 Dana 60 and Dana 70???? Aluminum is fine just want one with drain plugs, links to any websites would be appriecated, Thank you for your hlep
Old Sep 28, 2005 | 09:47 AM
Mark Craig's Avatar
flynhigh205,
I was confused by your post, are you saying you don't want aluminum and would prefer a steel one like stock if it had a drain plug? If so there are companies that sell a bolt in drain plug kit for trannies that should work for you.
Mark @ DPPI
Old Sep 28, 2005 | 10:36 AM
infidel's Avatar
Take your pick
http://froogle.google.com/froogle?q=...ff&oi=froogler
Old Sep 28, 2005 | 04:05 PM
Ruralmedic's Avatar
If you're simply looking for a drain plug, there was a post a month or two ago of someone that drilled and tapped the bottom of their rear axle/differential casting when doing a fluid change to accomodate a drain plug. It sounded like a simple procedure, and eliminates taking the rear cover off to drain for future changes.
Old Sep 28, 2005 | 07:53 PM
infidel's Avatar
One of these will also work, hard to beat $10 http://www.genosgarage.com/CoastalDa...ID=209&CATID=1
I personally have no problem just removing the cover to rag out the oil that doesn't drain and clean the magnet.
Old Sep 29, 2005 | 11:14 AM
steel or aluminum is fine I am more than likely gonna use the DT lift kit on my truck and i cannot use a Mag-hy-tec cover plus I really dont wanna spend 265 a peice for them, thanks for the help
Old Sep 30, 2005 | 09:05 AM
Mark Craig's Avatar
flynhigh205,
That's why I asked you to clarify your question, get the PML covers, way less money and gets you the same cast aluminum performance. Quite a bit smaller in overall diameter and should fit too.
Mark @ DPPI
upjeeper
Nov 6, 2008 07:41 AM
klx650a2
Jan 10, 2008 12:08 AM
gsdog1
Jan 30, 2004 07:58 PM
Commatoze
Oct 7, 2003 11:57 AM
wooff
May 1, 2003 11:22 AM
